Old 07-18-2020, 03:12 PM   #1
2012 25' FB Eddie Bauer
ATLANTA , Georgia
Air Compressor recomendation
Hi All
Looking at protecting AS during cold months when i may not be using AS for a week or so during the winter. Do not want to winterize with Anti-freeze because i will most likely be using AS most weekends during hunting season. Heard about blowing all of the water out of AS with air compressor but warned about using too much pressure. Any suggestions on good portable air compressor and how to protect pipes, etc during cold month when not in use would be appreciated. Live in Atlanta, GA so we occasionally get into the 20's during cold spells. Have a 2012 25' Eddie Bauer AS. Thanks, JHS
jschultz26 is offline   Reply With Quote
Old 07-19-2020, 09:21 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You need pressure..!but volume is just as important. I have cleared ours with a “pancake” comptroller... set the PSI around 50-70, drain all lines and water heater first. Leave all valves open. When you aren’t getting water out, you are done.
Don’t forget the P traps and toilet flusher.
Also, the waste tanks. And Fw tank. Drain then recap.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-19-2020, 09:33 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Winterize With A Bicycle Pump
The Fit RV has a great video showing that you can winterize your RV with a bicycle pump if necessary. The water lines act as a reservoir to create a sufficient volume of air to blow out the lines - one at a time. It will be slow, but doable.
A good 12 volt air pump like a continuous cycle VIAR 400 P will do an excellent job.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 07-19-2020, 01:37 PM   #4
ATLANTA , Georgia
Sounds good, thanks for feedback. Jason
Old 07-19-2020, 05:34 PM   #5
"Cloudsplitter"
If you are set on a portable go with quality, the larger the tank the easier blowing the lines will be, and more uses you will find for it.
DW poopoo'd my getting a large garage compressor, no more, too many other uses around the house.
Window seal-floor recomendation The Rambler General Repair Forum 2 08-27-2020 03:25 AM
Nashville Campground Recomendation? Marjon On The Road... 2 06-29-2011 05:06 AM
Hitch recomendation steven2themax Hitches, Couplers & Balls 2 10-08-2010 09:49 PM
Shock Recomendation gaylejoe Tow Vehicles 3 09-13-2010 01:46 PM
Winter Trip recomendation: Eagle viewing Boondocker On The Road... 36 12-06-2007 04:07 PM
