Old 11-03-2017, 10:53 AM   #101
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My low water drains are accessed between the tandem's on the curb side of my trailer. A pain to get to. Did my winterize yesterday.
Couldn't find my usual Prestone RV Antifreeze at Walmart. Looks like Walmart isn't carrying the Prestone product this year and I can't seem to find it anywhere in the metro area. Not sure if Prestone discontinued the product. After having a no name product melt the rubber bladder in a toilet in my SOB many years ago, I've tried to stick with a name brand product.
This year after some research I went with a product called Splash which comes in multiple strengths. I found it at Menards and I bought the -75 rated strength. Good price of $2.11 after rebate.
Here's an article I found on RV-antifreeze and probably explains why I had damage to my toilet one year.
Ethanol (alcohol) based: This type of antifreeze is most readily available in hardware stores and most RV shops it sells for approximately $3.00 – $4.00 a jug. However, this product is also extremely flammable and not to used around any sort of pilot flames or cigarettes. As well, this product has been known to taint certain RV plumbing systems and is only to be used with Quest or Pex plumbing lines. If you have ever used this product you will quickly remember how bad you water smelt and tasted the next spring. Furthermore, because this product is made from alcohol it works to dry out all the rubber seals readily found in your faucets and toilet. As a result we do not recommend or sell this product.
Propylene Glycol based: This product is only available at your local RV shop (and not every RV shop for that matter). It sells for approximately $5.00 – $6.00 a jug. Like the ethanol antifreeze, this product is non-toxic and safe for all RV plumbing. However, propylene glycol does not have the same fire safety warnings, nor the risk of tainting your RV plumbing system. Furthermore, propylene glycol is a lubricant and will actually work to extend the life of the seals in your faucets and toilets, unlike the ethanol based products. This is the only product we use on our own RVs and the only product we sell in our parts store. We have just received our first shipment of Propylene Glycol based anti freeze. We have it on sale at the following prices
Case Of 6 Gallons $23.94 (3.99 Gal)
$4.49 per gallon (each)
Propylene/Ethanol Blend: Again this product is non-toxic and completely safe for RV plumbing systems. It will cost more than $4.00 – $5.00 a jug. This may seem like a good idea, however, it is unknown how much ethanol is required to taint RV plumbing lines and dry out plumbing seals. For that reason we do not recommend this product.
I did a label check on the Splash product and it is Propylene Glycol. Here's the specs on what I used. http://www.splashwash.com/product/an.../rv-marine-75/
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 11-03-2017, 12:53 PM   #102
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Talked to a guy once who used vodka
Old 11-03-2017, 12:57 PM   #103
dznf0g's Avatar
Oswego , Illinois
Vodka belongs in my plumbing, not my trailer's plumbing.
-Rich-
Old 11-03-2017, 12:58 PM   #104
dznf0g's Avatar
Oswego , Illinois
-Rich-
Old 11-10-2017, 09:47 PM   #105
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Good info jack. I bought mine from homedepot and it’s the kind you say is good.
https://www.homedepot.com/p/South-Wi...7005/202530435
Troutboy
Troutboy is offline   Reply With Quote
Old 11-11-2017, 11:08 AM   #106
jcanavera's Avatar
Fenton , Missouri
Images: 143
Glad it helped. Yeah, way to much at stake if you screw up with the wrong stuff.
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 11-12-2017, 07:20 PM   #107
2018 30' International
cary , North Carolina
I’m buying a 2018 serenity. 30ft
Just watched your video
I think I willl want to get a compressor. The only use will be to winterize the rv
How would I know what size compressor to buy. I looked on Craig’s list and regretted are many types. Help?
gbradleync is offline   Reply With Quote
Old 11-12-2017, 09:50 PM   #108
CruizinDux's Avatar
Washington , Missouri
In a pinch a 12VDC inflator works, but just takes longer. I've used mine twice and it's fine. Here is an inflator thread http://www.airforums.com/forums/f42/best-portable-tire-inflator-172217.html
I bring this on all trips
Next step up is a 120VAC (tankless)compressor. It works better than than the 12VDC.
However if what you want is a tank compressor, IMO pretty much anything will work i.e. to start http://tinyurl.com/y8yeobfu which shold be fine. You want a continuous flow of air and not having the compressor running 100%. I limit the pressure to 55 or less.
I have a dual tank Rigid that a buddy gave me as he had two. It's overkill for winterization and tires...but it was also free. Supplies a very nice flow of air to dry out the lines nicely.
CruizinDux is offline   Reply With Quote
Old 11-13-2017, 08:25 AM   #109
Lumatic's Avatar
1993 34' Excella
Images: 16
I have a 2hp compressor from Harbor Freight. Cost less than $100. Had it for years.
Old 11-14-2017, 05:28 AM   #110
thanks
AS I get ready to receive the new rv The list of things "I NEED" seems to grow. Hopefully i can keep the weight down.
Old 11-14-2017, 09:22 AM   #111
CruizinDux's Avatar
thanks
That's why I carry the 12VDC inflator in the TT and leave the larger/heaver 110VAC in the shop.
That way I can top off PSI if needed and on one occasion to winterize on the road.
bob
Old 02-21-2018, 05:53 PM   #112
1964 26' Overlander
Palmyra , Virginia
For myself I don't use antifreeze. Instead I drain what I can. Blow out most of the rest. Then attach a small aquarium air pump to the system and let it blow air through the system for the next several days with all valves open and hand sprayers using rubber bands then I close all the valves and test the hand sprayers for sounds of bubbling. Since they have a loop in their hoses. If detected I will leave the one bubbling open for another day, then check the other and do it if necessary. At the end the lines are all bone dry with nothing left to freeze.
Remove trap plugs, crack waste valve, and cover air vents.
Scoutx is offline   Reply With Quote
Old 03-30-2018, 09:16 AM   #113
2016 26' Flying Cloud
Spooner , Wisconsin
Scoutx, your method has a lot of appeal to me, and it prompts a question that has occurred to me several times in this thread and in draining my AS a 2-3 times:
Can you blow air through the pump? (that is the pump in the plumbing that pressurizes the system when it use.)
I haven't been able to figure this out and hence I'm disconnecting the pump, installing a bypass for it, pumping anti-freeze into the pump and leaving a bit in it, before blowing out the system.
I have no idea what is inside the water pump (impeller, piston, magic?) but it just seems like if it can push water it shouldn't be able to have air pushed through it.
Okay, enough of my ignorance, do I need to do this disconnect/by-pass hassle, or can I just run this little air pump through the system?
WherryWillie is offline   Reply With Quote
Old 03-30-2018, 09:32 AM   #114
2007 22' International CCD
Consider adding the bypass valve and hose setup to the pump input to easily pump antifreeze through it. Campco makes one...
Old 03-31-2018, 12:04 AM   #115
1964 26' Overlander
Palmyra , Virginia
WW, Much would depend on the inner workings of your particular pump. That said, once the lines are dry, a quick start of the pump should remove any remaining water that might be an issue. You might then need another day to dry out the lines again. As long as you've not exposed the pump to water it shouldn't be necessary to dry it each time. You only need to dry out where water has been.
Old 03-31-2018, 07:57 AM   #116
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Before you start adding stuff to one side or the other of your water pump, take a good look at how much / how little space you have to work with on your trailer. In some cases, there really isn't much room to do this or do that.....
Old 04-02-2018, 06:44 PM   #117
2019 30' International
Pennsylvania , Pennsylvania
2016 Flying Cloud 25 here. For the Air Presuure Winterization method my manual says to open ALL faucets, shower heads, AND disconnect outlet to water pump.
Low point drains (2), and freshwater drain closed, hot water heater bypassed (FYI, mine has ONE valve to turn for HW heater bypass)
Then pump not more than 60 psi through city water inlet.
The manual does not say to open one fixture at a time, it clearly says open them all at the same time. (this results in a lower pressure in each line, and also resulted in a near continual bubble/gurgle at the outlet line that is removed from the water pump)
The fixtures, however, blew clear, without mist. It was the line removed from the pump that bothered me
So I closed her all up, and pumped the pink through
Second time pumping the pink this winter, first was in the late fall, this time just yesterday, after returning from a trip down south.
I just don't trust the 'air only' method yet, sorry
majorairhead is offline   Reply With Quote
Old 04-02-2018, 07:00 PM   #118
2016 28' International
Sioux Falls , SD
I don’t trust air only as well, never an issue.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-03-2018, 06:39 PM   #119
1964 26' Overlander
Palmyra , Virginia
If you're only using the air briefly to mechanically blow out the water, then I probably wouldn't trust it either, but if you follow the mechanical blow out with a long period of air flow and evaporation, then there will remain no water to freeze. Now I will grant this will take time, reasonable care and due diligence, but it will work and avoid introducing chemicals into the water system which can throw off the taste of your water.
But as with all things you need to decide for yourself which method best suits your needs, wants and effort to obtain an acceptable result.
For myself with ready access to shore power before, during and after storage that is on my own property, the time and minor effort is well worth it, to me. Of course if I was doing so in the middle of winter, then that might change my desire for a solution that could be obtained quicker though it might mean extensive flushing of the system next time it is to be used, and possibly a residual off taste.
Old 04-04-2018, 08:11 AM   #120
Half a Rivet Short
2022 Interstate 24X
Hi
Using air, you are trading the stuff that is in the compressor and tank for whatever is in the anti-freeze. The compressor has metal parts, rust in the tank, gaskets, rings and lube. If the hose got used with an oiler sometime in the past .... yuck ... Check the "quality" of the air before you *assume* it's good. A simple filter (dirt cheap at the hardware store) is also well worth the money.
No this isn't some sort of hypothetical thing. I *do* use filters on air lines and they pick up a lot of junk. Unless you use dedicated hoses for the job (never seen oil) the filter needs to be at the outlet end (which is indeed a pain ...)
winterizing - removed water filter - will it leak anti-freeze? Pudentane Fresh Water Systems 8 02-19-2013 09:39 PM
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
Remove Anti-Freeze Stains In Shower DEITZ645 Sinks, Showers & Toilets 4 03-23-2008 02:32 PM
Is anti-freeze required to winterize? guy99 Winterizing, Storage, Carports & Covers 17 11-23-2006 08:34 AM
No Anti-freeze smily Plumbing - Systems & Fixtures 8 04-15-2003 11:11 AM
