Old 05-20-2024, 04:20 PM   #1
2020 27' Globetrotter
South Jordan , Utah
Truck gate clearance with tongue jack motor
We have a 2020 Globetrotter, 27, the original tongue jack is still working but starting to make noise. Im inclined to replace it vs. attempt a repair. The present jack is Premier Performance, 4000 lb.
This jack is just barely small enough for our truck gate to lower completely without hitting the jack motor housing.
We are inclined to go with a Husky but they wont give any details on the dimensions of the jack, so we have no idea if their jack motor will interfere with our truck gate.
Has anyone else run into a truck gate interference problem with their jack? If so how did you solve this problem?
peterg5326 is offline   Reply With Quote
Old 05-22-2024, 01:20 PM   #2
2017 25' International
West Lake Hills , Texas
What is the make and model of your tow vehicle?
What is the make and model of your current jack?
The Husky can be mounted at ninety degrees from normal. Requires a couple of holes drilled in the tongue.
Fungus is offline   Reply With Quote
Old 05-22-2024, 02:39 PM   #3
Mollysdad's Avatar
Yes, and there's several factors. Obviously, the shank. Then the truck bed itself. I have a Tundra which is 23" tall.
That means a longer tailgate too. I selected the Husky 5000, and wrote a thread on how I turned it. It could be as simple as making a template, or marking the coupler area.
The conundrum is drilling new holes in the flange, since a drill won't lay flat along the shaft. If I were to do it again, I'd use a "drill bit extension" so I could get the drill past the shaft end. Instead, I just made holes 1/2" for a little wiggle room.
https://www.airforums.com/forums/f45...ys-196460.html
Put on your thinking cap. All jacks have the same bolt pattern. (3) 3/8" x 16 on 3" centers. So that puts the bolts 120 apart. You want to rotate 90 so 120 - 90 = 30.
You'll be drilling new holes 30 from the original.
Before you drill, you can choose left or right. I chose to turn to the curb side because the rubber cap covering the 'brake' on the jack is not facing the tank cover that way.
So, does it clear? Yes, but only by 1/4". That works fine as long as the truck and trailer are perfectly straight.
BTW, the Husky has lights on three sides, so you still get some light on the hitch if it's dark.
Mollysdad is online now   Reply With Quote
Old 05-22-2024, 03:50 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I bought a longer shank to allow for my tailgate to drop.
CRH is online now   Reply With Quote
Tahoe lift gate hits trailer jack Workbench Towing, Tow Vehicles & Hitches 10 05-25-2021 08:32 AM
23 FB too close to truck to drop the tail gate KWN306 Hitches, Couplers & Balls 46 09-07-2017 05:54 PM
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 04:41 PM
Operating Lights on Tongue Jack Motor BessieB Jacks, Stabilizers, Lifting and Leveling 7 09-18-2012 10:30 PM
