Old 02-15-2021, 04:30 PM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Tongue Jack malfunction
2020 international. The trailer has full power though the Jack is dead. Both Jack & light...no power. Any ideas?
s1000pre is offline   Reply With Quote
Old 02-15-2021, 04:37 PM   #2
2021 30' Globetrotter
East Northport , New York
Have you checked the fuse in the battery box?
James
Biker is offline   Reply With Quote
Old 02-15-2021, 05:03 PM   #3
2015 25' Flying Cloud
Schaumburg , Illinois
also suggest you follow the power wire backwards from the jack, make sure its not pinched, or cut, somewhere along the path. Since your trailer is so new, perhaps a manufacturing variation led to premature wear or outright failure (wiring failure)
1StreamDream is offline   Reply With Quote
Old 02-15-2021, 05:26 PM   #4
2018 25' International
Slidell , Louisiana
The jacks use the frame instead of a dedicated negative wire, so if the fuse is good, remove one bolt and improve the ground to frame by cleaning it. Or temporarily add a jumper back to the battery. If that works, take the jack off, remove the paint and corrosion and reattach.
Old 02-15-2021, 05:47 PM   #5
2020 23' Flying Cloud
Sebastian , Florida
Our jack blows its fuse whenever it runs up against the stop. The standard 15 A fuses I had on hand would blow immediately. I had to use the emergency crank to unhitch, and then run into town to get the larger size (Add these to your spare parts inventory if you haven’t already). End of problem, I just watched the jack position more carefully now.
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 02-15-2021, 06:06 PM   #6
s1000pre's Avatar
Yup...30amp fuse is toast! It looks like the propane cover worked it’s way through the wire.
Old 02-15-2021, 06:07 PM   #7
s1000pre's Avatar
Originally Posted by GetawA-S View Post
Our jack blows its fuse whenever it runs up against the stop. The standard 15 A fuses I had on hand would blow immediately. I had to use the emergency crank to unhitch, and then run into town to get the larger size (Add these to your spare parts inventory if you havenít already). End of problem, I just watched the jack position more carefully now.
Double check your 15amp... mine is a 30amp. It might be why your blowing fuses.
Old 02-15-2021, 09:00 PM   #8
Sebastian , Florida
S1000pre, Thanks for the advice. It actually only happened once, but all i had in the toolbox were 15A fuses, so I thought I’d give it a try. Lesson learned about having complete spares.
-Don
Old 02-16-2021, 05:02 AM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
My 2014 Barker jack specifies a slow-blow fuse.
2019 Ford Expedition Platinum
Old 02-16-2021, 05:24 AM   #10
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by s1000pre View Post
Yup...30amp fuse is toast! It looks like the propane cover worked itís way through the wire.
Folks, just curious. What brand and model jack is AS using on your trailers?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Jack one side with tongue jack extended? SeanWasHere General Repair Forum 33 07-31-2019 08:06 PM
OEM Super Jack Parts (aka Tongue Jack) Michael_Wild Jacks, Stabilizers, Lifting and Leveling 18 12-19-2016 02:47 PM
Electric jack malfunction jimgillio Jacks, Stabilizers, Lifting and Leveling 3 02-02-2014 09:23 PM
