Old 12-29-2022, 03:13 PM   #1
2014 27' Flying Cloud
Lexington , Oklahoma
Tongue Jack Electrical Problem
Barker HP 3000 tongue Jack keeps blowing fuse when engaging toggle switch in the lowering position. Jack works fine when raising. Replaced up/down toggle switch but the problem still exists. Could it be the limit switch assy? If so, is there a way to trouble shoot before replacing? Any thoughts?
Stream'n is offline   Reply With Quote
Old 12-29-2022, 03:20 PM   #2
J-Dog's Avatar
Rancho Cordova , California
At the time you were replacing the switch did you do a careful inspection of the wiring? You might have a chaffed wire causing the problem.
J-Dog is offline   Reply With Quote
Old 12-29-2022, 03:38 PM   #3
Thanks J-Dog. Yes, I did look over the wiring and also did a ohms check on those within the jack head. All looked okay.
OEM Super Jack Parts (aka Tongue Jack) Michael_Wild Jacks, Stabilizers, Lifting and Leveling 18 12-19-2016 02:47 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Electrical question - tongue jack toastie Batteries, Univolts, Converters & Inverters 17 03-22-2007 07:37 PM
