Old 07-31-2019, 12:09 PM   #1
Bcousins's Avatar
2015 30' FB FC Bunk
Zeeland , Michigan
Stabilizers
Ive always used 6x6 wood blocks under my stabilizers and I dont know why. Im looking to free up some space and make set up/take down easier, quicker. Getting rid of the blocks would free up bumper storage space and obviously eliminate having to get them out.
Is there an advantage or disadvantage to using them? Is a stabilizer more effective if only extended a short distance vs extended farther?
Bcousins is offline   Reply With Quote
Old 07-31-2019, 12:48 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
There are a few advantages to the blocks:
1. In some cases, the stabilizer alone may not be long enough.
2. You don't have to crank as far.
3. The greater area as compared to the stabilizer foot is less likely to sink in soft ground.
4. I have seen a couple of campgrounds that require blocks under the stabilizers to prevent damage to the paved pads.
That said, I don't carry wood blocks any more, just a sack of the yellow plastic lego blocks. I use them upside down to get more surface area in contact with the ground.
Al
You cannot reason someone out of a position they have not been reasoned into"
Old 07-31-2019, 01:18 PM   #3
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
we use the stacking plastic blocks. sometime we use 1 or 2 per leg
we also use many under the centre lift post
since they stack, they fit nicely in the outside storage area and can be easily cleaned off
waninae39 is offline   Reply With Quote
Old 07-31-2019, 01:41 PM   #4
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
We also use the plastic interlocking squares. Lighter than wood blocks. More adjustable for different heights and can act as a ramp/jack for tire changing and to level AS side-to-side at off level sites.
Will not splinter, rot, get moldy or attract termites either.
az-streamer is offline   Reply With Quote
Old 07-31-2019, 01:52 PM   #5
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Another vote here for the plastic blocks. I keep a set in the storage compartment and use them when the stabilizers need help with the "reach". I use a cordless drill (not an impact!) to lower and raise the stabilizers.
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-31-2019, 02:11 PM   #6
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Don't use any of that stuff and it seems to work ok ..... Less to haul around and fiddle with when you set up.
If indeed I *did* need to do something, I have a pretty good inventory of the lego blocks for leveling out the trailer.
Old 07-31-2019, 02:17 PM   #7
Trailer Sold, Waving
Acheron2010's Avatar
2019 26' Flying Cloud
Stettler , Alberta
I also use the plastic blocks, and they are especially handy when the site is short and the back end hangs out over a slope or loose soil/grass. I still hand crank them - it is part of my Airstream "gym," along with the 19 lb "barbell" Equalizer hitch bars.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 07-31-2019, 05:48 PM   #8
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
I use Lynx blocks and lids. the lids are useful to cover the Leggo like on block tops. I feel that the further the stabs go down, it wobbles more. So less cranking, the stronger the stabs are. Also good to prevent stabs from sinking in ground.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Electric stabilizers/levelers - information flyfisher Our Community 2 09-12-2004 11:48 PM
Cleaned up my BAL stabilizers... Sneakinup Jacks, Stabilizers, Lifting and Leveling 0 04-27-2004 06:29 PM
BAL stabilizers losing nuts? Kistler Jacks, Stabilizers, Lifting and Leveling 3 04-15-2004 07:50 PM
BAL Stabilizers kamadeca Jacks, Stabilizers, Lifting and Leveling 1 11-28-2003 01:32 PM
