04-26-2021, 01:06 PM
2018 27' Tommy Bahama
Napa
Stabilizer
What to do with stuck stabilizer- won’t extend? Wrong tool provided by AS in initial tools kit to hand crank . Dealer gave me a small hand crank with fork like end to “try!”.
04-26-2021, 01:15 PM
2015 20' Flying Cloud
Kingsport
That looks more like a manual backup crank for a power tongue jack; that does not look like my stabilizer crank.
Of course, I've gotten a socket to use w/ a cordless drill, makes the whole affair much easier to deal with....
-Leslie
WBCCI #1051
04-26-2021, 02:49 PM
2015 25' Flying Cloud
Schaumburg
I think it’s a 3/4 socket, but I suggest that before you get carried away with an overpowering torque, try spraying a lubricant like WD40 or similar into the areas where mechanical movement takes place. Might also need to let that soak for a few minutes. If you put too much force into a “stuck” stabilizer you might bend or shear something and produce a more permanent problem than you currently face. They are not the strongest ... definitely not strong enough to lift the frame, only meant to remove some of the bounce when walking about inside.
04-26-2021, 03:20 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
You are looking for one of these, and as the others mentioned...don’t force anything!
04-26-2021, 11:49 PM
Napa
Agreed I was concerned about using any power tool and thot a lubricant is needed. Is WD 40 the best? I know you shouldn’t use a silicone base spray. Interesting that AS dealer & service didn’t have more reliable information.
Thanks fir the suggestions.
04-26-2021, 11:56 PM
Napa
Wow! I certainly didn’t see that at the dealer and it was not among the assorted hand cranks they brought out! But excuse my lack of knowledge how can you turn that underneath the trailer there’s not enough clearance. Here’s pic of stab’s end where it would have to attach.
04-27-2021, 12:01 AM
1999 34' Excella
Hillsboro
Design change.. the drive shaft on most others I have seen have a standard 3/4” 6 point, bolt head. That Not the same setup as majority in use.
So the one they gave you is sadly the one to use it seems. Clockwise to lower.. at least on the other design s..
Peace and Blessings..
Channing
WBCCI# 30676
04-27-2021, 12:08 AM
Napa
Thanks fir directing me to lubricants my research indicates PB Blaster and Liquid Wrench are even better than WD40.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
steering stabilizer
ALANSD |
Mechanics Corner - Engines, Transmission & More... |
34 |
04-01-2014 09:48 AM |
Stabilizer Jack Installation
uwe |
Jacks, Stabilizers, Lifting and Leveling |
16 |
11-11-2004 05:39 PM |
Steering Stabilizer
rdm |
2 |
09-17-2004 06:03 PM |
steering stabilizer
cooperhawk |
3 |
07-17-2003 04:37 PM |
