Old 05-08-2025, 05:25 PM   #1
KettleKayaker
2019 27' International
Glenbeulah , Wisconsin
Rivet Removing both wheels from one side of 27 ft International
Hi All,
In the next few days I am planning on removing both wheels from one side of my 2019 27 ft International. I will replace both both shocks and inspect the brakes and possibly replace the brake backing plates. After the first side is done I would move on to the other side of the trailer. Looking for some suggestions as to the "best practice".
It seems to me that having the trailer hitch attached to tow vehicle as an additional point to provide some stability would not be a bad idea. I would use the floor jack under the "diamond" of the jacking point and a bottle jack for safety.
Has anyone used a similar process to remove both wheels from one side of the trailer at time? Suggestions?
2022 F-250 Lariat SuperCab
2019 International "Sweet Serenity" 27 ft FB
KettleKayaker is offline   Reply With Quote
Old 05-08-2025, 06:38 PM   #2
Ginophiles's Avatar
2017 30' International
Paradise , California
Just a thought. Instead of doing 2 wheels on each side at once, do 2 wheels on each axle. When we installed the Dexter lift kit on our 30' International, we got 2 heavy duty plastic car ramps from Harbor Freight. About $60 for a pair.
Then put one in front of the front tires on either side and pulled the trailer forward up onto the ramps leaving the back 2 wheels in the air. Installed the lift brackets on each side of the rear axle. Backed down and moved the ramps behind the rear wheels and repeated for the front axle.
Very easy. We liked it so much we keep one of the ramps in our rear storage area should we need it, and we did. Rolled into an RV park last fall and found a separated tread on the trailer tire. Deployed the ramp to the good tire and lifted the bad one up. Left it like that while we took the wheel for a new tire.
Ginophiles is offline   Reply With Quote
Old 05-08-2025, 07:32 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I’ve done it twice, both times at Discount Tire. I had them install Dill metal stems and later replace the tires.
Use the tow vehicle connected to the trailer and the rear jack point. It will do the job. In your case I’d put a jack stand between the wheels on the frame in case the jack fails.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is online now   Reply With Quote
Old 05-09-2025, 06:08 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I do exactly what the OP planned to do and jeffmc306 pictured.
2019 Ford Expedition Platinum
Old 05-09-2025, 07:08 AM   #5
Mollysdad's Avatar
I put a bottle jack between the tires using the axle support beam. (where the shocks attach) If it's going to be up for a while, then I put a jack stand at one end of the axle support beam.
I disconnect the truck so I can use it for tools, etc.
Old 05-09-2025, 07:22 AM   #6
2019 28' Flying Cloud
Broward , Florida
Were you able to use the floor jack on the sewer side of the trailer? I don't know what the FC 27 looks like, but on the FC 28 the sewer pipes seem too close to the designated jacking point to use a floor jack, so we used a bottle jack instead.
Andy543 is online now   Reply With Quote
Old 05-09-2025, 07:42 AM   #7
KettleKayaker
Thanks for your ideas and photos! I'll start this project in a few days. (I have clear access to the jack points on my 27 ft international. One reason why I wanted both wheels off on one side at the same time, is so that I can rotate the tires while the other work is being done).
Old 05-09-2025, 07:58 AM   #8
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
I actually changed out the axles on my trailer using jack stands at the rear lifting points and 4x4 cribbing at the front jack points as well as the factory jack at the front. Worked out fine. But it's a pain. You can place the tires under the trailer at the frame corners as an extra safety margin.
Keys Dave is offline   Reply With Quote
Old 05-09-2025, 08:15 AM   #9
2000 25' Safari
2007 27' Safari FB SE
1995 25' Excella
Woodbine , Georgia
I did this same procedure minus the shocks just a few weeks ago. After looking at various ways to lift the trailer--I took Ginophiles' route. I decided that doing each axle instead each side at a time was faster and MUCH safer for the safety of me and the Airstream. Instead of buying the ramps I made them out of 2x8s I had laying around.
gamakai is offline   Reply With Quote
Old 05-09-2025, 08:18 AM   #10
2022 27' Globetrotter
Bethlehem , Pennsylvania
Another option is to lift off ALL the wheels use jack stands.
1) Lower the jack all the way.
2) place jack stands under the jacking points on each side of the trailer.
3) raise the jack until the wheels come off the ground.
Magic! Because the jack points are behind the axle and the suspension has very little travel, the axles don't drop much as the jack is raised. I saw this done at Colonial Airstream and I had my brakes done this was at my house. The jack has the same load on it that it normally has (about 940 pounds in my case) and each jack stand has half of the remaining weight (about 3200 pounds each). Easy peasy.
This guys shows a similar method on a horse trailer.
Merlintiaga is offline   Reply With Quote
Old 05-09-2025, 09:15 AM   #11
2014 25' FB International
Sacramento , California
Always leave one tire on each side, safety first!
dmartinez is offline   Reply With Quote
Old 05-09-2025, 10:30 AM   #12
2012 23' FB International
Woodstock , Ontario
I prefer to use the Axle Frame for jacking point, but if you use the AS point then put some blocks under the axle frame if you intend to be under the wheels or trailer.
Agee that hooked up to the vehicle is a more stable set up. No chance of the trailer twisting off the jack
JCWDCW is offline   Reply With Quote
Old 05-09-2025, 11:37 AM   #13
jeffmc306's Avatar
McHenry , Illinois
Andy, no issues on the street side of the 27’ but if you hade a clearance issue, a bottle jack would work.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 05-09-2025, 12:53 PM   #14
1985 31' Excella
st. Paul , mn
I would suggest to any preferring to their own work / repairs - build a ramp for both side [ that you tow the trailer onto ] , might do a double - in separate , one lower to be just high enough to take off wheels [ both sides at the same time ] .
The 2nd to put in front of the 1st - a 2 step , the 2nd for additional hight to give more room for other repairs that require more room .
ONE big suggestion ---- always use jackstands to hold trailer at working hight .
NEVER --- rely on any type of jack to hold trailer up while working under !!!
I use to be in the repair bis ---- and have seen many failures [ not using jackstands ] .
Leaving trailer attached to tow vehicle is good also .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 05-10-2025, 08:25 AM   #15
2015 28' International
Palm Beach Gardens , Florida
I do the same as Molly's Dad, however I put a jack stand at each end of that shock support rail, then remove the bottel jack to do the other side, scine I am in the garage on a level concert surface, I do not hook up the truck. I just recently did this to replace the hubs and install new brake magnets.
Jimmyg561 is offline   Reply With Quote
Old 05-18-2025, 01:00 PM   #16
Mike0392's Avatar
2019 33' Classic
Estes Park , Colorado
Yep i used my ramps too.
Mike0392 is offline   Reply With Quote
Old 05-18-2025, 02:48 PM   #17
OneToFixIt
1981 31' Excella Limited
Belton , Missouri
This is easy and very safe for the trailer and person
Easy way to lift 2 wheels
OneToFixIt is offline   Reply With Quote
Old 05-18-2025, 03:59 PM   #18
2016 30' International
redondo beach , California
Put the entire trailer on axle stands.
Service the brakes.
i'll bet a beer/Costco hot dog that the shocks are fine.
Note that whatever method used, the trailer will flex and the door will open/close differently.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 05-19-2025, 02:07 PM   #19
TrvlTin
2023 30' Globetrotter
Boulder , Colorado
My New Favorite Way
Purchased a couple 8 ton black jacks Walmart.
The bottle jacks hold, though I did add more fluid and I crank it a little bit tight on the valve, but then they hold for the day
Made blocks
3 cranks a piece back and forth up. Goes up smooth.
Chocking other side.
I’ve needed to replace one axle.
Mine are 4500 the piece and I’m avoiding putting all the trailer weight on one. Axle.
Tipping it at the centerpoint where the axles are seemed the best place to avoid frame flex.
ID:	453372   Click image for larger version
TrvlngTinTin is offline   Reply With Quote
Old 05-19-2025, 11:03 PM   #20
OneToFixIt
Belton , Missouri
Axle rating includes a safety factor
Responding to the concern that lifting a whole trailer on 1 axle will exceed the weight limit of a single axle.
I’m not concerned at all by this. The shock and vibration load on an axle, frame and trailer spike up and down as it goes down the road. Sitting static in a single place while servicing the axle brakes is not a concern.
Also as a trailer naturally goes over terrain, such as a speed bump or pothole, either axle will naturally experience loads well beyond their load rating.
In engineering design, there must be safety factor. What it takes to bend any part of an axle is a multiple (4x-6x?) of a the axles rating.
Professional Mechanical Engineer with 27 years of experience here.
Removing wheels on one axle Jason P M Jacks, Stabilizers, Lifting and Leveling 10 08-12-2024 10:53 AM
Tips for removing both wheels to replace both tires chaeha 2005 and newer - Bambi all models 27 12-31-2021 08:11 PM
Removing All Four Wheels At One Time kdinnar Tires 32 04-21-2018 01:01 AM
1965 airstream travel trailor & 1965 ford p/u step side selling both drive away! eBay Watch Airstreams on eBay 0 07-29-2013 07:30 AM
one side wore out other side good hshovic Tires 5 06-25-2009 06:31 PM
