11-11-2018, 03:52 PM
Yaphank
Manual override crank for Atwood premier power jack
I have a 2017 Atwood premier where do I purchase the override crank handle for it since my jack is not working
11-11-2018, 04:07 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 👍
The Amazon is your fiend....👍😂
11-11-2018, 04:08 PM
Yaphank
Originally Posted by ROBERT CROSS
The Amazon is your fiend....[emoji106][emoji23]
[emoji631]
Can't seem to find it on there
11-11-2018, 04:10 PM
Yaphank
Out of stock on Amazon
11-11-2018, 04:13 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
11-11-2018, 04:29 PM
2019 27' Globetrotter
Salem
, Oregon
You can get a drill attachment. Try Amazon. Dave
11-12-2018, 09:20 AM
Watertown
, Massachusetts
vice grip
Just get a large enough vice grip and attach that to the end of the post and spin the handle around to go up or down. There is nothing special about that tool.
11-12-2018, 09:37 AM
Yaphank
[emoji106]
2017 19' International
Highlands Ranch
I bought mine from my AS dealer and tossed it in the toolbox to have on hand when necessary.
11-12-2018, 10:00 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
If it has a square configuration like the Barker jacks, then a twelve point 7/16” socket attached to 12” or longer extension will allow turning jack screw without taking propane tanks off trailer. The “included” handle from Barker was so short it would only do 180 degree swings before hitting propane tank enclosure.
11-12-2018, 10:15 AM
2014 27' FB International
Hooper
, Utah
Atwood makes two different configurations of the handle crank. Make sure you are getting the right one!
Check your slow blow fuse which is located in the power line just below the power jack. The connection works its way loose and pops open all by itself. Make sure the fuse is not blown. I had mine come apart, and when there is no connections, the power jack does not work. A simple 30 cent part. A jack handle will cost you $35.00. I also purchased one for a backup and also a box of fuses. NAPA Auto parts stocks the fuses. AS will charge you an arm and a leg for the same part. NAPA is also cheaper than Amazon. As I remember the fuse is a 15 amp SLOW BLOW fuse.
11-12-2018, 11:21 AM
Yaphank
The fuse looked the light on the jack works I think the fuse is 30 amp. Airstream just provided me with the socket not the crank handle when I took delivery of the trailer. When I put the socket on my drill it won't turn the nut.
11-12-2018, 11:44 AM
2011 20' Flying Cloud
Lemont
Before you buy anything, take a look at the jack in your tow vehicle. When my Barker jack stopped working, I found that the jack handle in my 2012 Toyota Tacoma used the same size square fitting as the Barker.
Glenn
11-12-2018, 11:55 AM
Yaphank
Is the Barker the same as an attwood
11-12-2018, 12:59 PM
2018 23' Flying Cloud
2018 25' International
Grafton
, WI
Atwood jack
This might not help you now but, we just got our new AS and they supplied a manual crank handle with the purchase.You said yours was a 2017.
11-12-2018, 01:18 PM
Yaphank
Yes they just supplied me with a socket
11-12-2018, 05:35 PM
2016 30' Classic
Victoria
, British Columbia
We also did not receive a crank for our Atwood jack. The first “slot” head crank that we purchased appeared to be the correct one, but the socket was slightly too large to enter the opening in the jack. I subsequently purchased a socket head that fit. If any members purchase a crank, ensure that it fits the jack before tossing it into the tool box.
11-12-2018, 05:43 PM
Yaphank
I just put a big vise grip on the socket and it worked fine
11-12-2018, 05:45 PM
Yaphank
Now I called an RV repair man to check the switch on the jack hopefully that's all it is.
11-13-2018, 06:35 AM
2016 25' Flying Cloud
Selbyville
, Delaware
Colonial shipped my jack handle to me plus a half dozen slow blow fuses for the atwood. Good to have since I’m on my third new jack on my 2016 FC.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Atwood Premier Performance Series Power Jack w/ Robofoot
KJRitchie |
Jacks, Stabilizers, Lifting and Leveling |
4 |
08-01-2016 07:31 AM |
Does this jack have a manual override?
NicheVintage |
2 |
01-16-2010 11:00 PM |
elec jack won't work, manual override won't budge?
Randjg1 |
17 |
07-04-2009 09:19 AM |
Electric Tongue Jack Manual Override
overlander64 |
10 |
05-07-2009 09:22 AM |
Can you get a manual crank head for a power jack?
JimGolden |
2 |
08-05-2007 05:00 PM |
