06-19-2022, 04:28 PM
#21
2022 25' Flying Cloud
NCR
, Ontario
we have used LevelMate Pro for 3 years now
no issues
works very well
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
WBCCI# 21212
06-19-2022, 06:42 PM
#22
2021 30' Globetrotter
Oviedo
I put my iPhone on the kitchen counter and eyeball it level. Then I make sure water runs Doen the shower drain and call it done.
06-20-2022, 05:58 AM
#23
2019 27' International
Rogers
, Arkansas
You Do or You Don't
Originally Posted by Life is a Highway
My Level mate is my mate. The girl says one block here two there and we’re usually dead on. Then she checks it with the real level inside. Does the bathroom door swing or stay put
I get a big kick out of KYD jumping out of his rig ohhhh it’s time to use the iPhone level app.
I love technology but I’ll pass on the level mate
So you do or you don't have any experience with RvLevelerPro or Level Mate?
06-20-2022, 09:32 AM
#24
Freedom
2023 30' Classic
Dallas
, TX
I have a Level Mare Pro. I tried it for a while, but I found by the time I turned it on my wife could simply put a level on the floor and instantly tell me if we were level side to side. If not we immediately know we need to get the blocks out and level. It is very quick and easy for us, so we no longer use the device.
2023 30 Foot Classic
2022 Ram 3500 Dually
06-20-2022, 10:21 AM
#25
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Well, I received my LMPro unit 4 months ago...and I was going to install this trip, but I am a "bit" off the side to side buble....need to move the AS when it stops raining..maybe tomorrow, and hook em up to see how this thing works. Seems some of you have good luck, and others have "interference"? I will hook up, and use for month of July as we head to Gros Ventur and then Glacier for 4 weeks of travel... Looking forward to using this new contraption...so is the "manual level gauge reader; DW!) Will report back once I have installed.
06-20-2022, 11:08 AM
#26
2022 27' Globetrotter
DALLAS
, TX
My mate has never been level. But I married her anyway.
06-29-2022, 05:28 AM
#27
Rogers
, Arkansas
Pretty Much the Same
Originally Posted by Mikebrady62
I just purchased the RVLevelerPro. I will let you know once it is installed how it works compared to the LevelMatePro. I had the same issue (not accurate) with my LevelmatePro purchased in 2020. I thought it was worth a try for $50.00 less. If I get another 2 years with it, I'll call it a win.
I have now used the RVLevelerPro a few times, all with good success. Very much the same as Levelmate Pro but $50.00 less. I like each because I can see just exactly how far to pull on to the levelers before I stop, then exactly how far to raise or lower the front without having to stop and look myself or have my wife giving me hand signals. (she is really good at 1 hand signal when parking ) All she does is turn it on and go about here routine.
So far, so good.
06-30-2022, 05:59 PM
#28
Drew
2017 23' International
Beverly
, Massachusetts
LevelMate Pro or RvLevelerPro
I bought the RV Leveler a few months ago and have used it a half dozen times now and it’s worked perfectly.
The key feature that any of these devices give you is the ability to back into or pull into a spot and stop at the level spot. Then there is no need for any side to side leveling blocks or ramps.
06-30-2022, 07:59 PM
#29
2021 30' Flying Cloud
2020 25' International
minneapolis
Originally Posted by Ephraim
I’m not familiar with that product but definitely post what you find. We currently use LevelMatePRO but I get frustrated with it. It works well and I’ve had no issues with the unit itself but there is no security in the connection and no ability to choose units. It is not uncommon for the app to grab a neighboring unit while I’m in the cab of the truck leveling side to side on Anderson levelers. The unit just grabs the strongest signal it finds and no one seems to turn their unit off when they are done leveling.
Your response came to mind last night when I opened up my Mopeka propane tank app to check my levels. To my surprise, I had 4 tanks of propane.
- Stewart
06-30-2022, 09:44 PM
#30
2022 28' Pottery Barn
¯\_(ツ)_/¯
Interesting. My LevelMate Pro (using the battery) shuts off automatically and I have not seen any other signal interfere with my readings.
Same thing with the Mopeka tank sensors- never had any other signal show up. I recall having to pair these in the setup, can’t recall with the LMP setup.
07-01-2022, 05:29 AM
#31
Rogers
, Arkansas
There is not a pairing function for either the Levelmate Pro or the RVLevelerPro. So although I have never encountered another unit showing up, it is definitely a possibility. They both have an auto shut down too.
07-01-2022, 09:24 AM
#32
2019 30' Classic
Belen
, New Mexico
the auto shutdown only works when it is battery powered. Many use the + version which can be powered externally. I do, but I turn the switch off when not using it. Most who use this feature just leave it on all the time.
