10-21-2020, 08:21 PM
2015 25' FB Flying Cloud
Austin
Leveling FC25FB
Been at it around 6 months and still can't seem to figure out a routine for the whole leveling thing.
1st- I start with front to back
2nd- We do side to side
If we don't get it just right the door wont close properly. That's kinda of the tell.
I am checking this with a level and although things appear level, we still have a few cabinets and drawers that just wont close correctly. We also use the stabilizers to stop the trailer from flexing as we walk around.
Any ideas?
10-21-2020, 09:27 PM
2017 22' Sport
NCR
, Ontario
IMHO, switch the order
we use LEVEL MATE PRO. it sites inside the trailer and talk to your phone with Bluetooth.
when we get on site, the unit starts up and i use the TV and the red ramps to get L-R level. then i disconnect and park the vehicle.
next i level the unit F-B still using LEVEL mate.
then i lock down my stabilizers and lock the SIX JT's Strong Arm Jack Stabilizer system
they work great to prevent any rock and roll inside
10-21-2020, 09:53 PM
2013 31' Classic
billings
, Montana
Side to side first..every time..if not level..put stackable blocks down...now it is level..side to side... install X chocks on both sides.....unhook...Run electric jack up or down...you got it...then drop stabilizers..
10-21-2020, 09:55 PM
2013 31' Classic
billings
, Montana
Any ideas?
...nope...side to side first...the front to back...  real easy
10-21-2020, 10:04 PM
1997 25' Safari
Montgomery
, Alabama
First, I’d get a large level that mounts to your trailer just below the front window and is viewable in your inside rear view mirror.
Wheel Masters makes a nice one.
Then, acquire a set of those ramp style levelers. there are now several Better alternatives to these “Anderson style” levelers on Amazon.
The process...pull or back into your site. When “in the ballpark” on an irregular surface, check your level in the rear view. Sometimes you get lucky and a few feet back or forward will get you level side to side. If not, deploy your levelers on the low side , pull or back onto them watching the level. When level, apply the park brake until you (or your spotter) places the smaller triangular piece as a chock.
Now you can unhitch and use the tongue jack to level front to back. There Is a front/ back bubble level on the Wheel Master and many tongue jacks have one.
There are lots of other gadgets you could use but that is the sequence. Side to side first, then front to back.
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
10-22-2020, 06:19 AM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
Any ideas?
For the door you might be using the stabilizers as leveling tools and that is pushing the door area up and making it hard to close. As others correctly pointed out level first then stabilize. Mine is a 30' and I lower the stabilizer and when it takes a load, done.
If you feel the trailer moving front to back take a look at your chock system is it really blocking front to back or consider X chocks.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
10-22-2020, 08:44 AM
2015 25' Flying Cloud
Tucson
As others have said, you should switch your order. level left-right first, then front-back.
10-22-2020, 09:49 AM
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
We have been Airstreaming for a long time, 2,180 nights over 14 years. We pull into a campsite, put our level on Lucy's rear bumper. We use lego blocks to level side-to-side. We then unhook Lucy from the tow vehicle. We put the level on the side belt line and level front-to-back with the tongue jack. This works every time.
Reading the OP's post, I get the impression that he may be doing his his to side leveling with the stabilizer jacks which is causing his door problem. Saying that he is leveling front-to-back first makes me think that he is unhooking first and therefore he cannot level side-to-side except by trying to use the stabilizers. This will torque the trailer causing all kinds of alignment problems.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
10-22-2020, 10:03 AM
2017 22' Sport
NCR
, Ontario
if you level L-R with the AS jack, they will eventually fail and collapse.
they are NOT levelling jacks, they are meant for stability.
Do as others have stated and use tire leveling block or ramps when the As is connected to the TV.
Then disconnect and do F-B using the jack
