Old 09-25-2023, 04:19 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
jt strong arm- final install
when i first got our FC 25FB, the dealer installed 4 of 6 JT strong arms. The tech could not figure out how to install the two side ways rams.
as the foot is wider on the 2023 FC, it does not work with the lippert 4" swing bolts.
i found the lippert 314592 adapter lug and used it to bolt the side arms onto the angled leg as there was already a suitable hole to mount it.
here is the final install of the two side arms ( the front to back were done already) on an FC 25FB at the read
Name:	lippert 314592.JPG
ID:	437249   Click image for larger version
Name:	jt strong arm-centre mount.jpg
Name:	jt strong arm-lippert 314592 bracket.jpg
ID:	437251   Click image for larger version
Name:	jt strong arm-rear foot mount.jpg
Name:	jt strong arm-side and rear mount shown.jpg
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
waninae39 is offline   Reply With Quote
Old 09-25-2023, 07:08 PM   #2
2022 27' Globetrotter
DALLAS , TX
Can you please share what problems you were trying to solve via this upgrade?
foobar is offline   Reply With Quote
Old 09-25-2023, 10:07 PM   #3
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
I'm also curious what they are for?
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
Can of beans is offline   Reply With Quote
Old 09-25-2023, 10:23 PM   #4
waninae39's Avatar
NCR , Ontario
with JT strong arms , no more shake or movement
it works FANTASTIC, my wife loves it as it stabilizes the whole trailer
File Type: pdf jt StrongArm install manual-sept 2023.pdf (2.47 MB, 13 views)
File Type: pdf lippert jt strong arm travel trailer.pdf (2.29 MB, 11 views)
Old 09-26-2023, 10:19 AM   #5
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
There was movement with your four stabilizer jacks properly set?
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
Hermes is offline   Reply With Quote
Old 09-26-2023, 11:09 AM   #6
waninae39's Avatar
NCR , Ontario
AS provided leg are for leveling. in the manual they state that
the JT strong arms are only locked in place after you are level
the JT strong arms provide front to back and side to side stability
they are also very common on 5th wheel trailers
Old 09-27-2023, 06:40 AM   #7
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
AS Legs Are for Stabilizing
the JT strong arms provide front to back and side to side stability.
I hope you miss printed that. If I use my stabilizing legs to get to level, they would most likely bend. I use my hitch jack and tire levelers to get level and then put my stabilizers down to just snug. They really do make a difference, but I would never use them to get to level.
Mikebrady62 is offline   Reply With Quote
Old 09-27-2023, 07:30 AM   #8
Loco Airstreamer
shannon's Avatar
1970 23' Safari
Denton , Texas
Lots of factors there, but if you're pretty level to begin with? Why not put a little tweak on one side, just a little bitty one?
shannon is offline   Reply With Quote
Old 09-27-2023, 10:07 AM   #9
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Mikebrady62 is absolutely correct - the jacks on an Airstream are called stabilizing jacks, not leveling jacks, for a reason. They are not intended to level anything.
Not even a little tweak - if you have to use the stabilizing jacks to correct an out-of-level situation your trailer wasn't level enough to begin with.
These side-to-side & front-to-back supports being discussed are interesting, but how do they improve on having solid tire chocks and properly placed stabilizing jacks? Never seen them in person so not sure how they work.
Richard
11018
richard5933 is offline   Reply With Quote
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 10:47 AM
True North Strong and Free tinhutjohn Member Introductions 3 04-16-2007 06:23 PM
Is this a strong enough tow vehicle? atticus_ar Tow Vehicles 25 01-15-2007 09:46 PM
Airstream and strong winds Devoman Our Community 29 08-30-2005 09:48 AM
Spring Bars Strong Enough? Navigator Hitches, Couplers & Balls 2 10-05-2004 09:48 PM
