07-08-2022, 01:50 PM
2019 30' International
Pennsylvania
, Pennsylvania
Jack Stands
I've seen reference over the years regarding the use of jack stands for various purposes. I've looked around the site for specifics on type/size etc. but haven't found anything specific.
What weight rating would you recommend for a 30 foot Airstream?
Links to your favorite style, size, weight rating jack stand greatly appreciated
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
07-08-2022, 01:56 PM
1994 25' Excella
Waukesha
, Wisconsin
I've had great success with a pair of these:
Great thing about these is that they combine the jack and the jack stand, meaning that you can use them in the lift point behind the rear axle and not have to find another place to put the jack stands.
Since the tops of these are not flat, I use a small block of hardwood between the top and the jack point to protect the trailer.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
07-08-2022, 01:57 PM
2016 28' International
Trois-Rivieres
, Quebec
I use 2 ton stands. If you were to support the trailer with 4 of them (wheels off the ground) that would give you 8 tons of capacity, which is way above the trailer's weight. Anything bigger will be heavier. You can find them on Amazon. But you have to be careful where you place them, same caution as for jacking the trailer.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
07-08-2022, 02:18 PM
Pennsylvania
, Pennsylvania
Say a guy wanted to lift the rear axles and remove all 4 wheels, putting the entire airstream weight on two jack stands. Will two 2 ton stands suffice?
I've seen pictures on this site of this being done, but no reference to the size/weight rating of the stands.
Thanks for your replies thus far, I appreciate it.
07-08-2022, 02:50 PM
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte
, North Carolina
8K pounds should take care of any Airstream, including the motorhomes as maximum Workhouse RV chassis was 16.5K 3#s.
I would have a 3/4" piece of plywood or a 2x10 (assuming it covered the jack footprint) cut for each jack to ensure the jack doesn't sink into the surface.
07-08-2022, 03:05 PM
Moderator dude
1966 26' Overlander
Phoenix
Some points on heavier metal areas (not marked for support) of the trailer will not handle high loads. This is because the trailer design is NOT a body on frame design. It is a monocoque ior semi-monocoque design. The exterior sheet aluminum takes some of the load of the trailer.
Place a jack stand in an area not marked for lifting or support and the "frame" can bend. Non-marked areas are not designed to take loads like a full framed automotive vehicle.
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - Still Streamless. But have brand X TT.
07-08-2022, 04:38 PM
Escape Pod II
2022 23' Flying Cloud
2018 22' Sport
Orange
How much does your trailer weigh? Subtract your tongue weight from that and divide by two and that would be the weight that each jack stand would be supporting at the axle support which is where I put my jack stands.
JEWare
07-08-2022, 04:51 PM
Moderator dude
1966 26' Overlander
Phoenix
Why would you subtract tongue weight on a static trailer?
Would the tongue still be attached to the TV?
Plus I would want static support to be far in excess of actual load.
At least 150% of actual or max load.
Action
07-08-2022, 05:10 PM
1994 25' Excella
Waukesha
, Wisconsin
Action
Whether the trailer is hitched to the tow vehicle or supported by the tongue jack, the tongue weight is being supported by something other than the axles.
That said, I agree that you want to have a buffer in the capacity of the jacks/stands, in excess of the actual weight on the axles.
Richard
11018
07-08-2022, 05:39 PM
Escape Pod II
2018 22' Sport
Orange
I only stated how much weight each jack stand would be supporting. I didn't include the capacity of the jack stands needed because I'm not sure what the industry recommends which is probably 2X the supported weight.
JEWare
07-09-2022, 06:36 AM
Oswego
I personally use 6 ton stands. When I was working and the AS was stored all winter, I used 4. Now it never sits very long and I use 2 for servicing purposes.
I don't mess with marginal capacities when I have my pieces and parts under heavy objects. The cost differences are negligible. My AS has about 8500# on the axles.
-Rich-
07-09-2022, 06:57 AM
Escape Pod II
2018 22' Sport
Orange
Rich, mine are 6 tons also for a 3 ton trailer.
JEWare
07-09-2022, 07:26 AM
Tampa
Be sure to know what you're buying.
I'm very happy with the Harbor Freight jack stands, they seem overbuilt, but the weight rating is for the PAIR, not individually. So if you buy 6 ton jack stands, each supports 3 tons.
I used them as a backup to my floor jack, and so I placed them at the rear of the axle support rail.
07-09-2022, 07:28 AM
Pennsylvania
, Pennsylvania
I appreciate all the responses. Thanks!
07-09-2022, 07:31 AM
Pennsylvania
, Pennsylvania
This is the kind of information that's important.
https://agradetools.com/jack-stands-rating/
07-09-2022, 07:36 AM
Pennsylvania
, Pennsylvania
One more thing.
What do y'all prefer in terms of ratchet paw vs. pin style for locking them in place? Are the ratchet styles reliable?
07-09-2022, 07:41 AM
Oswego
One more thing.
Yes, if they are a robust casting and latch.
I have pins. Less convenient, but a sure thing as far as robust design.
-Rich-
07-09-2022, 09:19 AM
Moderator dude
1966 26' Overlander
Phoenix
I have both as well.
My pin type is made of thick sheet metal and the stand has got wear not in the pin lock area. In the foot of the stand. I had a vehicle shift a couple of times so now I always use left over plywood under those stands. The stand bottom bites into the wood.
Ratchet type is newer technology. Both have been very secure as far as the pin or ratchet.
Action
07-09-2022, 01:25 PM
Tampa
Indeed. It was a good read.
By the way, people think of Harbor Freight as selling "China junk" and maybe that's true in some items, but the things I've bought that were welded steel (The hydraulic lift table, jack stands) seem overbuilt, if any complaint, it's they're too HEAVY!
I have a couple of their breaker bars and I stood on one with a 3' section of pipe added to break a bolt loose, and the 1/2" breaker bar flexed about 10 degrees but didn't snap. I was surprised.
07-09-2022, 01:36 PM
2015 20' Flying Cloud
Kingsport
, Tennessee
I've gotten a good bit of things from HF. Jack stands might be the one things I'd avoid from there, maybe... Awhile back, there was a recall on their stands, they had replacements you were to swap them out for, then they had to recall the replacement jack stands.... FWIW....
(My Craftsman stands are ancient, but, still at work... )
-Leslie
WBCCI #1051
