10-30-2020, 07:39 PM
2004 25' Classic
Hanahan
, South Carolina
Jack is a little crooked
My jack is a little crooked. Not as much as the flag pole indicates as it is a loose fit and exaggerates the lean.
Any ideas or suggestions on straightening it?
Thanks to John Leake “Sandlapper” for the flag pole holder...
10-30-2020, 07:49 PM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
Is the jack plate on top of a star washer and that is tipping the jack?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
10-30-2020, 08:02 PM
1966 22' Safari
Fredericksburg
If it’s not the star washer as GCinSC2 pointed out, you could loosen the bolts and add some stainless steel washers as shims to plumb it straight.
10-30-2020, 08:09 PM
Any day now....
2019 30' Flying Cloud
Katy
There are worse kinds of crooked jacks...
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
10-31-2020, 11:07 AM
2021 27' Globetrotter
Tallahassee
, FL
Your jack looks mounted sideways. Did you do the modification?
10-31-2020, 11:58 AM
2004 25' Classic
Hanahan
, South Carolina
Mine came mounted that way but I understand a lot of people turn them to make room for the flag pole holder.
I will look for a star washer but I’m not familiar with that.
10-31-2020, 01:37 PM
Somewhere
, South Carolina
Planenut,
Some directions suggest putting a toothed (star) washer between coupler and jack post plate for grounding purposes. Bites into both metal surfaces. It COULD shim the jack and cause the tilt you're reporting.
The idea of using a purposefully placed washer as Bubba L suggested to correct the tilt is a decent idea too.
Might as well inspect coupler to jack mounting plate for bends etc.
Gary
S/OS #001
10-31-2020, 02:14 PM
2019 30' International
Pennsylvania
, Pennsylvania
To this old eyes that flagpole looks way more out of plumb than that jack post.
Yeah, the jack post might not be exact, but that flag pole there, something doesn't look right. It's leaning more than the jack post.
JMHO
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
10-31-2020, 04:52 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Mine was side ways and bent. Forgetting to raise the jack before attempting departure will do that, leaving a big deep furrow in the roadway. Lesson #4691 and counting.
guskmg
10-31-2020, 07:15 PM
2004 25' Classic
Hanahan
, South Carolina
The flag pole holder to flag pole has a little slop so it exaggerates the lean... a little Tape to tighten the fit will take a lot out.
I see a small gap on one side where it is bolted down but no star washer. Perhaps I can shim it up and tighten up a bit.
Thanks.
JMHO
11-01-2020, 09:33 AM
Somewhere
, South Carolina
Try cutting sleeves from a plastic coffee container. Wrap them around the pole and slide in to flag holder.
I have same holder just three pole version.
S/OS #001
11-01-2020, 10:38 AM
Tampa
I've heard that theory, and although it's good for grounding, I never do that. It allows water to puddle in the space and develop rust. I put the star washers on top of the jack mounting plate. I use grade 8 bolts and they don't rust and seem to chase the threads in the frame so I have a good connection.
When I'm king, I'll order all jacks to be two wire.
11-01-2020, 10:39 AM
Spokane
JMHO
That is what I thought as well. Jack looks straight enough to me.
11-01-2020, 06:26 PM
Somewhere
, South Carolina
Originally Posted by Mollysdad
I've heard that theory, and although it's good for grounding, I never do that. It allows water to puddle in the space and develop rust. I put the star washers on top of the jack mounting plate. I use grade 8 bolts :
We’re on the same page. My comment was for troubleshooting an angled jack post.
Not how to install it.
S/OS #001
