04-13-2004, 03:36 AM
1977 31' Sovereign
electric jack...that darn fiber gear again!
I've got a '77 Sovereign and it has it's original electric jack. The problem is that it seems to eat up that big fiber gear about every two years, and this is with maybe 5 trips per year.
Is this normal?? Does anyone know of a source for these gears that's less than the nearly 30 bucks I've been paying?
Thanks for any leads on this....
Guy
04-13-2004, 08:21 AM
New Borockton
, Alabama
That fiber gear is the biggest failure on the whole jack. I keep an extra one in stock all the time. They are available through dealers but $26 is the least I ever paid for one.
Randy
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
04-13-2004, 08:50 AM
In the Nick of Time
Well this is bad news.
But I am so glad to read about this problem. I was just getting ready to buy the jack head from another list member for 85.00.
If the innards are junk-engineered I think I'll pass. Thanks guys.
I'm still able to crank.
However I have never heard others complain of this weakness in part eslswhere. Could it be a misaligned gear train, due to a dent etc? Seems if this were widespread I would have seen other folks much PO'd. I read alot of forums pretty thouroughly and this is my first encounter.
Could you all further ID the brand/model# etc. jack-motor you are condemning please.
Is the 26.00 part(gear) from the manufacturer? Or a retailer?
EDIT I just found some info thanks to the "similar thread" feature that follows this thread. http://www.airforums.com/forums/showthread.php?t=4069
But still wonder if this is the same model that you are talking about.
Thanks again
04-13-2004, 09:05 AM
New Borockton
, Alabama
Don't buy a new jack head yet. The part is made by Barker Manufacturing. I think the key is to baby the switch. In other words, up or down with a pause between or it will eventually strip. Don't go past full up or full down. My first one lasted 24 years (that I know of because it looked original) and the second lasted only two years until I figured out how fragile they are. My dad has stripped a few too.
In edit, I would not say the jack innards are bad, or the whole jack for that matter and maybe there is a way to align the gears better but the fiber gear is under suspicion to me.
888-828-1893
Bestconverter.com
04-13-2004, 09:10 AM
Just a member
1978 28' Argosy 28
Lutz
The gear is likely engineered to be a failure component. It is cheaper to replace than a burnt up motor because the gearing jammed, Etc.
I did not have this problem in the past with my Jacks, but I babied them as I had heard that if you did not they could loose a gear.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
04-13-2004, 10:02 AM
Still Working
1994 36' Classic 36
North Charleston
, South Carolina
Seat the head
It is imperative that the whole assembly is seated upon re-assembly.
As you may have noticed, it is tight quarters and the wiring is very short. It does not take much for the wire to get under the gear. This will provide for a weak mating between drive gears and rotary gear.
I did not have a problem with the gear but I have disassembled a couple and repaired other problems.
I would watch Ebay for a whole head, they come on there every now and then.
As for the 85 dollars unit. I would buy that any day over cranking, been there and done that. I guarantee if you ever go electric you will not crank back
But Jaco Cranko, kinda catchy
Smily
04-13-2004, 10:17 AM
New Borockton
, Alabama
Smily
There is nothing wrong with the head when you hear the spinning of the motor and no action from the jack. It's a sound you will know. It is the fiber gear. If you need a head, get the head but the gear is what's wrong most of the time. If your jack is dead, you can even get a motor and not a whole head from Barker or Ebay but I don't think that is the problem. I too would buy a whole new jack before cranking, that will wear you down quick.
In edit, Ken is right that reseating the cap correctly and making sure the wires don't get in the way of the gear is important but the fiber gear will still strip in time anyway.
888-828-1893
Bestconverter.com
04-13-2004, 12:22 PM
MrTimbo
1975 31' Sovereign
Newberry
, South Carolina
We have painted a red stripe on our jack right before it is fully extended and before fully retracted. This way you will always know when to stop the jack.
Tim
04-13-2004, 12:28 PM
Still Working
1994 36' Classic 36
North Charleston
, South Carolina
limit switches
If your jack is working correctly and it is synchronized properly, there is no need for indicators like red lines on the shaft, (although this is a good preventative measure). There is a limit switch in the head that stops the motor at both extremes. it is a small microswitch. This switch can cause some confusion for a novice electrician. There are more wires than you would think necessary. The extra wires provide for the limit switch.
Works good when everything is in its place.
Smily
04-13-2004, 12:51 PM
2004 30' Classic Slideout
Fenton
, Missouri
I guess the question was asked but does this jack require syncronization when the head is pulled off? If it does, and you aren't doing it after putting things back together, then you may be looking at why this gear fails so rapidly.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
04-13-2004, 12:54 PM
Still Working
1994 36' Classic 36
North Charleston
, South Carolina
Ding Ding Ding
Jack, I believe you have hit it right on the head. I dont remember seeing any reference to synchronizing in this thread.
We shall see soon, I am certain.
Smily
04-13-2004, 07:35 PM
Corona
All electric jack "heads" must be in sync with the jack post.
If it is, the internal switches will prevent the jack from reaching either extreme position.
Most fiber gear failures are not caused by wear and tear, but by being out of sync.
04-14-2004, 05:16 AM
1977 31' Sovereign
Okay....that synchronization thing sounds plausible. Now that I think about it, the failures have occurred when someone other than me, was operating the jack!
Now the question.....how does one synchronize the jack??
Guy
04-14-2004, 08:43 AM
Corona
Who's jack?
04-14-2004, 04:45 PM
1999 25' Safari
Manchaca
Jack Sync instructions
If it's a Barker jack there are some PDF's here with instructions
http://www.barkermfg.com/product_ins...tructions.html
WBCCI 1845
04-15-2004, 05:17 AM
1977 31' Sovereign
I can't really tell what brand of jack it is...the logo is too faded. It does appear as if it is probably the original jack that came with the trailer. The up/down switch is located on the bottom of the motor itself on mine. I've ordered the fiber gear from an Airstream dealer several times, and they've always sent me the correct one without asking which jack I have, so it must be the original equipment one.
Guy
05-04-2004, 02:34 PM
1977 31' Sovereign
Well, I received the new fiber gear and was all ready to install and "synchronize" the jack today.
I removed the head and I don't see anything but two gears in there...no limit switches! I tried grounding the motor against the frame and running it to see if the limit circuit was in the motor housing, but apparently not. It just kept running.
Could this jack just simply not have limit switches, thus no need to synchronize? I wish I could read the make and model of the jack, but it's just gone.
Any ideas?
Guy
05-04-2004, 05:10 PM
Still Working
1994 36' Classic 36
North Charleston
, South Carolina
A thousand words
I have an idea, send pictures!
We can help you if we can see what you are working on.
Smily
05-05-2004, 05:25 PM
1977 31' Sovereign
Hmmm...a picture.....good idea!
I hope I can figure out how to do that....Let's see what happens.
Guy
05-05-2004, 09:18 PM
Hey DOH
Thanks for the barker link. I found the owners manual for my
jack and found out where the switch for the lights are.......BONUS!!!!!
