Old 07-06-2017, 04:35 PM   #1
2017 30' Flying Cloud
Astoria , Oregon
Question Electric jack button - no way to lock it?
We live in a full-time park for now (3 months) and bought our Flying Cloud 3 months ago. From the start I was a bit concerned that there is no way to lock the jack button and anybody walking by can potentially play with it and cause major damage. I may be a worry wart but that's exactly what happened when my grandson was visiting. He has to push every button he sees, typical boy I guess. Thankfully I was right there and stopped him. Did any of you install something or know of an easy fix to prevent this? Since we will be here for quite awhile I guess I could tape something over it just not sure what that would look like.
tschambo is offline   Reply With Quote
Old 07-06-2017, 04:42 PM   #2
Airstream Obsessed
AVDESIGN's Avatar
2006 30' Classic
1989 29' Excella
Sandy , Utah
On mine, I have a fuse holder on the wire that leads up to the main unit. When I put the trailer in storage I raise jack and then take the fuse out. Voila!
AVDESIGN is offline   Reply With Quote
Old 07-06-2017, 05:14 PM   #3
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Installing a battery disconnect switch inside a locked battery box or inside the trailer is another way to address this and other issues. By putting it between the negative terminal and the chassis ground it will disconnect everything in the trailer.
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 07-06-2017, 05:17 PM   #4
2011 23' FB Flying Cloud
2008 19' Safari SE
Brossard , Quebec
Jack button solution
I experience the same situation!
I install a weather proof plastic box with a 30 Amp. switch in the cable power line from the battery.
Simple solution. See picture.
Michel
Papou is offline   Reply With Quote
Old 07-06-2017, 05:19 PM   #5
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Removing the fuse between the jack and the batteries, as mentioned above, is probably the easiest way to disable the jack while still being able to use the rest of the trailer.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 07-06-2017, 06:41 PM   #6
2000 30' Excella
Toledo , Ohio
Just put a cover over the jack out of sight out of mind . I keep a canvass bag over mine all the time .
woodfox45 is offline   Reply With Quote
Old 07-07-2017, 01:32 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Don't know what brand of jack you have but ours ... a SuperJack ... has a metal cap that screws on over the jack switch ... we also cover the jack with a vinyl bag with velcro closures at the bottom, when camping and storing to protect the fact from the elements and curious kids. Removing the fuse is the easiest and sure-fire way to prevent meddling.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 07-07-2017, 02:49 PM   #8
Watertown , Massachusetts
unplug jack
We have the same concern because we live near the local HS, and the kids congregate near our parked trailer when ever they have a fire drill. We made a modification inside the battery box that unplugs the jack from power. We only plug it in when we are going to use it. We also added locks to the battery box.
sallye is offline   Reply With Quote
Old 07-07-2017, 02:49 PM   #9
Sag Harbor , New York
Most tongue jacks are wired directly to the battery, bypassing the Use/Store switch and any aftermarket battery disconnect switches. And the ground for the jack is the metal housing which bolts to the frame.
Which is why the fuse removal suggestions are good IMO. Just have to make sure you can find that small fuse later, or have some spares around.
Old 07-07-2017, 06:01 PM   #10
Astoria , Oregon
Thank you all. Taking out the fuse sounds like the easiest way to fix this and a bag over the electronics to protect from the elements is the other good idea. Problem solved. I'm so glad this forum exists ��
Old 07-07-2017, 07:29 PM   #11
Cannonball's Avatar
2024 23' Flying Cloud
San Antonio , Texas
Camping World has a vinyl bag jack cover for about $10. Cinch cord and very discreet.
Cannonball is offline   Reply With Quote
Old 07-09-2017, 10:54 PM   #12
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I concur
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Inexpensive way to protect your 7-way plug SmokelessJoe Lights - Interior & Exterior 6 03-05-2011 03:08 PM
2-way vs. 3-way Dometic loriday Refrigerators 12 08-15-2010 10:21 PM
Push button deadbolt lock jendon Doors & Locks 0 03-09-2010 06:14 PM
2 way or 3 way Refrigerator? New or Old? prairieschooner Refrigerators 10 09-13-2006 10:45 AM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 04:33 PM
