Old 03-22-2021, 02:53 PM   #1
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
Dead Jack
iíve been putting this question off for too long now, so here goes. A while back, I took the trailer in for a brake job. The trailer sat for a few days after repairs were made, so when I finally went to hook up, the batteries were dead. I connected the Bargman 7pin up to the truck and found the jack did not work. All the lights were working, the brakes worked great, signals worked, but not the jack. I also learned that the batteries did not charge while being towed. That jack worked just fine when plugged into the 30 amp post, fortunately. The truck is a 2019 Silverado that only had 14,400 miles on it at the time.
My questions are: Should the jack have worked even though the trailer batteries were nearly dead. Second, if so, should there be current at the white or black pin of the Bargman, and how to test that. One of my earlier Silverados needed a fuse installed if towing, could that be the case here? Jim
Rig: '97 30' Limited
Towed by: '19 Silverado 2500 Duramax
WBCCI #22116
JimW is offline   Reply With Quote
Old 03-22-2021, 04:29 PM   #2
1986 31' Sovereign
Miami , Florida
Sounds like the 12VDC charging line in the 7way is not working. Your Silverado may not have come with the fuse inserted in the correct slot.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 03-22-2021, 05:59 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
The jack is "usually" hooked direct to the batteries. If the batteries were dead or almost dead, ther would not be enough 'Juice" to use the jack. It draws quite a load. You would not get enough charge into your batteries from just being connected to the truck. Get a test light and see if there is power to the charging terminal on your 7 pin connector.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 06-03-2021, 08:16 AM   #4
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
UPDATE
As it turned out, the AC to trailer circuit fuse (slot #2) was burned out and has been burned out since soon after purchasing the truck. I do have an idea what caused the fuse to blow. What I learned definitively is that the jack does work robustly even when both batteries are dead. Hooray! I was surprised to learn that that circuit must aid trailer braking as I had to decrease the Gain by almost half, 10 down to 5.5. I bought an extra fuse and a fuse puller that Iím carrying at all times.
WBCCI #22116
Old 06-03-2021, 09:04 AM   #5
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Good news you found the problem. In a similar event, now that I've added lithium batteries to the Airstream, I needed to disconnect the 7 pin from charging the batteries when hooked up. Imagine my surprise that my 2017 F-250 not only did not have the fuse in that position but did not have the relay either. All this time I'm being careful to disconnect after travel, and the batteries were not even hooked to my trailer's charging circuit!
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
<2mo Old - Dead Batteries Dead Electricals GT2018WA Electrical - Systems, Generators, Batteries & Solar 9 05-29-2018 01:48 PM
house battery seem dead/ shore power dead joe rv guy Sprinter and B-van Forum 29 12-26-2016 12:36 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
