Old 03-28-2021, 11:27 AM   #1
GHR
2020 16' Basecamp
Altamonte Springs , Florida
DC power source for new power hitch jack
I have 2020 Airstream Basecamp and want to install an electric power jack but need a DC power source to connect it to. I do not see a DC buss bar on the outside of the Basecamp anywhere so I guess I need to find a way to get the cable from the outside in the front to the inside where the battery connections are located. Any recommendations on best place to penetrate the shell with a 12 gauge wire?
GHR is offline   Reply With Quote
Old 03-28-2021, 11:32 AM   #2
Images: 59
Can you just tee into the 12v power supply on the 7-way umbilical?
Old 03-31-2021, 01:24 PM   #3
FaFaFooey's Avatar
2021 20' Basecamp
Franklin , Wisconsin
On our BC 16 I ran a wire in through the lower fridge vent and into the battery compartment to that bus bar. Some jacks pull high amps so make sure your 7-way wiring can handle that if you go that route.
FaFaFooey is offline   Reply With Quote
Old 04-01-2021, 12:28 PM   #4
GHR
2020 16' Basecamp
That sounds good. The fridge vents to the outside someplace? Is it easy to find?
Old 04-01-2021, 12:29 PM   #5
GHR
2020 16' Basecamp
I looked at just splicing into the 12v wire for the 7way plug but the 7way wires are all sealed inside a rather hefty all weather cable that I would rather not cut into if possible.
Old 04-27-2021, 10:20 AM   #6
2021 16' Basecamp
San Jose , California
I had the dealer install our electric jack, and they routed the cable through the Zamp Solar plug outlet. While I could have done this myself, they already had the trailer for another issue to fix (minor issue), while there, I just had them install this and a backup camera.
ID:	394278   Click image for larger version
stemcc is offline   Reply With Quote
Old 04-30-2021, 06:30 PM   #7
ThB
2021 20' Basecamp
Gresham , Oregon
Very helpful idea. Thanks for the pic. Although this is a little off topic for this thread, I'm curious which back-up camera you had installed - and how it's working?
Thayne
ThB is offline   Reply With Quote
Old 05-01-2021, 09:32 AM   #8
2021 16' Basecamp
Thayne
Thayne,
I purchased DoHonest License Plate camera, inexpensive, and should have been really easy to install. You pull off one of the lights and tie into the wires. However, when I started to do this, I found that there was no electricity going to these lights, which is why I actually had the airstream in for service, so they ultimately ended up installing it for me.
I haven't gotten used to it completely yet, being at such a low level, it's more difficult to determine your distance to whatever you might bump into while backing up, than say one that is mounted above the door and pointing down. However, I love being able to use it as a rear view while driving, super helpful in that regard.
Regards,
Stephen
Power Jack - battery source power? Schiappiv Electrical - Systems, Generators, Batteries & Solar 12 10-19-2019 05:56 PM
Power Source Battery Charger / Power Supply T Reno Batteries, Univolts, Converters & Inverters 0 10-01-2018 10:24 AM
Power hitch jack DrKnow 2011 - 2015 International 0 12-03-2012 03:17 PM
EQ Hitch & Raising the Bars w/Power Jack mstephens Towing, Tow Vehicles & Hitches 20 11-07-2012 10:00 AM
Power hitch jack - fried? Toasty's Dad Hitches, Couplers & Balls 9 02-06-2006 10:26 AM
