View Poll Results: What kind of levelers do you use?
lumber scraps
57 |
36.08% |
plastic lego-like leveling blocks
99 |
62.66% |
other - please explain
9 |
5.70% |
none - I'm ok with a little lean
3 |
1.90% |
07-18-2009, 06:47 PM
#21
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
All of the above....
For Janet,
keep's 'em from scoot'n around.
07-18-2009, 07:12 PM
#22
Central
, Mississippi
We use both. The plastics are for quick stops and the only issue we have is in low temps they have exploded!
dirt and gravel do tend to crack them also
07-18-2009, 07:58 PM
#23
1999 23' Safari
Perrysburg
, Ann Arbor
Interesting thread. As usual, lots of good ideas.
I use 5/4 pressure treated deck boards, beveled ends, just long enough to support both tires on one side ... lifting one axle might be enough, but seems to me doing that puts a lot of unneeded strain on the axle carrying the load. If the boards ever die (haven't so far), I'll probably replace them with Trex recycled plastic deck boards. So far (knock on wood) two of those plus a little judicious digging have proved adequate for my purposes.
07-18-2009, 08:45 PM
#24
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We use two sets of Legos. We have changed numerous flats on the trialer with them. We have also used them to adjust Lucy's brakes. We also use them to make a ramp to change the oil in Olivia and Daisy.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
07-19-2009, 12:31 AM
#25
Salem
, Oregon
None of the above.
Hi, I don't have anything to level out my trailer; Sometimes you can pull farther foreward or back up a bit in the space to find a more level spot. I like the idea of having something use while changing a flat tire, but I haven't had that privilege yet either. [lucky so far]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-19-2009, 01:23 AM
#26
1978 28' Ambassador
Morada
We use the RV Pillo...yeah, it's a bit more $ than some left over lumber scraps and 'lego type' interlocking blocks...
But, it's really easy to get our AS level when we pull into a site...
1. back into or stop at desired final trailer position.
2. lay the RV Pillo next to the wheels on the 'low' side.
3. pull trailer ahead enough so that you can slide the RV Pillo inboard, into position.
4. back trailer wheels, back onto the RV Pillo.
5. lay the wedge, 'brake' block between the wheels - this block wedges the wheels when the Pillo is inflated, acting like a parking brake.
6. inflate with portable compressor.
7. adjust for and aft 'level' with the tongue jack.
8. get a beer out of the ice chest and relax...
We've used this rig about 10 times now, and it's been easy to set up each time, without any problems...it made of several plys of HD flexable material, and can be folded to store away - we put it in a plastic bin with our air compressor - the last item loaded so we can easily get to it when we stop...
Here's a picture from RV Pillo's web site, showing the installed position...
Ray & Pat; Morada, CA
07-19-2009, 03:10 AM
#27
Baltimore
, Maryland
I use three 2x8's. The first one is just slightly longer than the dual axles. It has a 45 degree angle cut on the ends to make pulling on easier. The second one is the slightly longer and the next slightly longer. This allows me to get up to 4.5" of lift on one side if needed. Often, if the site is level I will put one under each wheel. I find this very convenient and they go right in the back of truck. For changing a flat(never had to, but have changed rubber on many a recovery for clients) I just pull out the floor jack and lift the whole trailer. I always carry a chunk of 6x6 for the jack. It saves on cranking too much.
07-19-2009, 03:24 PM
#28
Food For Thought.....
Makes me wonder if the orange legos have a useful service life. The orange wheel chocks we use are stamped with a service date. The photo on the right reads "REPLACE AFTER 2011".
Kevin
William C. Swinney
07-19-2009, 04:41 PM
#29
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
Go up or Go down
here's what I use most of the time-- to raise the tire.
sometimes at unimproved sites (dirt) I will use my entrenching tool to lower the tire. (dig a hole) whatever it takes to keep the fridge sorta level to have cold beer and coleslaw.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
07-19-2009, 04:51 PM
#30
sometimes at unimproved sites (dirt) I will use my entrenching tool to lower the tire. (dig a hole) whatever it takes to keep the fridge sorta level to have cold beer.
Looks suspiciously like red wine to me...Is this the apporved beer substitute for those times when you just cant seem to get the rig leveled?
William C. Swinney
07-19-2009, 04:58 PM
#31
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Great idea d.g.
I see, eat the meal and sit on the high side, excellent
07-19-2009, 05:00 PM
#32
1963 28' Ambassador
Northern VT
, Vermont
Our bed is on the street side, I have the isle side position .. With my wife I leave the streetside low, with my girlfriend I leave the curbside low. When I'm huntin' with the guys I get PERFECT level with blocks!!! She sees this I'm DOA!!!!!
07-19-2009, 05:13 PM
#33
1977 27' Overlander
Trotwood
, Ohio
I forgot to mention, I also carry trenching equipment (very short handled shovels,I have his and hers ) so I can did a hole if I need too. I looked all over for the collapsible shovels that were used by our Soldiers for digin foxholes with no luck, seems their aren't many army surplus stores around anymore.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
07-19-2009, 05:23 PM
#34
Certifiable
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
07-19-2009, 05:46 PM
#35
1963 28' Ambassador
Northern VT
, Vermont
Surplus [or style] entrenching tool. Cheaper than dirt. Sportsmans guide. Campmor. all .com.
07-19-2009, 07:25 PM
#36
1999 23' Safari
Perrysburg
, Ann Arbor
Roger - remind me to show you the one I'm still using, that I got surplus in about 1955, when I was a kid and just started camping. Still works fine, and it's dug a lot of holes! I'm pretty sure it'll outlive me.
Ryanh
07-19-2009, 07:38 PM
#37
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The all-around Camp Tool....have had this one "forever."
Really comes in handy around the campsite.
09-17-2011, 01:12 PM
#38
1979 31' Excella 500
1973 25' Tradewind
Cinnaminson
, New Jersey
Have always used the lumber. You can add as needed.
I just got another trailer (31' 79' Excella) and now I need a new set. I found some old 2x6x6, three of them, not sure if they are pressure treated or not and was thinking of painting the bottoms.
I also found some 2x12 for the tongue jack, screwed the together to eliminate them splitting
What is everyone opinion who use the wood?
Tom Beitz
6760 PA Unit
TAC NJ-5
Riverton, NJ
09-17-2011, 02:44 PM
#39
Maniacal Engineer
Lopez Island
Since we sometimes find ourselves in seriously unlevel camping spots, we use 2x6 lumber. I cut different lengths so they can be stacked w/o problems. I use 1' square sections of 3/4" ply for the stabilizer jacks since they love to sink in on soft ground. The tongue jack goes onto a chunk of 6x6.
I still need to make some proper chocks for the trailer; I'd like to make them so I can tighten them in place w/ the same 3/4" socket I use with the electric drill on the stabilizers.
- Bart
09-18-2011, 11:11 AM
#40
2022 23' Flying Cloud
2006 28' Safari SE
Gold Beach
, Oregon
We've been using lumber but just purchased the plastic blocks. It will be interesting to see how the blocks work but I'll be bringing both.
Idmtman
2022 Flying Cloud 23FB (Yalla)
2010 Toyota Tundra 4x4
TAC: ID-1
