10-22-2021, 06:16 AM
2018 30' Flying Cloud
Sanford
Attwood 4000 tongue jack repair
I have a 2018 30' bunk, and the Attwood 4000 tongue jack gears have stripped; it just spins but doesn't engage to lift. I'm doing it manually now.
I talked to the dealer, and they said there should be a gear kit, but didn't have one. Does anyone know of where I might be able to find one? Any good source to find a replacement if the gears aren't available?
Thanks!
David
10-22-2021, 06:25 AM
2004 28' Classic
Monument
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
10-22-2021, 09:11 AM
2016 27' International
Sherwood Park
, Alberta
This jack has been a pretty popular replacement when folks get tired of replacing the gear assembly in the stock Atwood jack.
https://www.amazon.com/Husky-82084-S...O%2CB001TICRRQ
10-23-2021, 04:49 AM
Sanford
I ready up on the Husky, and ended up just ordering one of those after reading about all the problems with the Attwood's. I ordered the 5000lb model though.
Thanks!
David
10-23-2021, 11:50 AM
2016 25' Flying Cloud
Nanoose Bay
, British Columbia
I’m assuming when you said “dealer” you meant the dealer who sold the AS to you and not Atwood.
I had failed micro switches in my Atwood so I emailed Atwood direct and they immediately sent me replacement parts (not for free of course). If you haven’t tried Atwood direct give them a shot.
Gary Nijman
2016 Flying Cloud 25 FB Twin
2018 GMC 3500 Denali Duramax
10-24-2021, 07:16 PM
2018 27' Flying Cloud
INDIAN HARBOUR BEACH
Stripped Gears . . .
Any idea why or how the gears stripped.
I would like to avoid stripping the gears instead of replacing them.
10-25-2021, 09:54 AM
Moderator dude
1966 26' Overlander
Phoenix
Over loaded
Lack of lubrication
Debris got into the gears causing wear
Action
10-25-2021, 02:59 PM
Sanford
I tried calling Attwood, but couldn't get through, and gave up. I didn't see a way to email them.... I spoke to the Airstream dealer originally, and he tried to order the gears for me, but said they were on a long term backorder.
My understanding is that Airstream only used this model for a few years, and switch brands due to too many failures. I ended up buying the Husky, as that one seemed to be the most common replacement by Airstreamers from my reading. Hopefully it will be better. My jack failed after about 2 years. I greased the shaft periodically, and marked the high and low points so as not to grind against the stop. It was the original jack, and I bought the trailer new, so it shouldn't have ever been overloaded.
10-25-2021, 06:29 PM
2004 28' Classic
Monument
Did you ever even try to contact etrailer.com. I checked. They have rebuild kits. See post #2.
DaveP
2023 Ram 3500 4x4
10-26-2021, 02:52 AM
Sanford
I saw replacement gears for other manufacturers on etrailer, but not for Attwood. Do any of them cross reference?
10-26-2021, 05:24 AM
Springfield
, Ohio
Experience tells me that it's cheaper in the long run to replace a failing jack than to try to prolong one's life. I've been there and wasted a lot of effort to have the jack fail anyway.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
10-26-2021, 05:33 AM
2014 25' Flying Cloud
Cuddebackville
, New York
I've had Atwoods on both of my Airstreams since 2007. I've opened them up of regrets but have never found it was needed.
I did have a switch go bad and got a new one from Atwood for $20. All found them online for $10 (searching for the switch not Atwood).
2019 Ford Expedition Platinum
