Old 03-25-2023, 10:12 PM   #1
2019 27' Tommy Bahama
Waterloo , Ontario
Anderson Levelers
Anyone have any experience with the red Anderson Levelers especially with duel axel? I'm seeing mixed reviews on the interweb.
I see threads here with people using the Lego blocks but that seems time consuming considering the Anderson's boast a one and done philosophy. Lifetime warranty seems like a plus too.
Anyway thanks for taking the time.
TonyT is offline   Reply With Quote
Old 03-25-2023, 10:23 PM   #2
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Beech Lane are a much better choice than anderson. anderson have a breakage issue.
sheriff1 is offline   Reply With Quote
Old 03-25-2023, 10:36 PM   #3
Waterloo , Ontario
Nice. Didn't even know about that brand. They even look better in the pics. Thanks! By the way did you have to cut the end of one of the levelers due to the dual axle? Assuming you have dual.
Old 03-25-2023, 10:47 PM   #4
2020 30' International
Ingleside , Illinois
I have been using the Anderson levelers for two seasons and about to start a third. They have worked great with zero problems.
JohnandDonna is offline   Reply With Quote
Old 03-25-2023, 10:50 PM   #5
Waterloo , Ontario
Good to hear. As always it's never an easy decision.
Old 03-25-2023, 11:00 PM   #6
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Been using the Anderson with zero problems. Once you get a communication system between your spotter and driver it just works.
Richard
11018
richard5933 is offline   Reply With Quote
Old 03-26-2023, 12:41 AM   #7
Senior Member
sheriff1's Avatar
Sparks , Nevada
Yes, cut one a bit shorter. Do a google search on Anderson block failure.
Old 03-26-2023, 05:33 AM   #8
2022 27' Globetrotter
Bethlehem , Pennsylvania
With Anderson levelers and Levelmate Pro, I can level my dual axle trailer on first try every time by myself. I did trim my Anderson levelers. Took about 2 inches off. I cut between the holes through the plastic.
Merlintiaga is offline   Reply With Quote
Old 03-26-2023, 06:08 AM   #9
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
The Anderson levelers and the LevelMate Pro are a great combinations.
I too had to trim a bit off the length but have had no issues with breakage. Be aware that they can slip when pulling onto them.
Old 03-26-2023, 06:36 AM   #10
2023 27' Globetrotter
2019 27' Flying Cloud
2004 25' Safari
Williamsburg , Virginia
Andersen levelers have worked very well for us in three seasons. Still holding up well.
AgBullet is online now   Reply With Quote
Old 03-26-2023, 08:02 AM   #11
AKNate's Avatar
2018 30' Flying Cloud
Anchorage , Alaska
Both of our Anderson levelers have cracked in half. Yes, they have a lifetime warranty, but that doesn’t do you much good when they crack in the middle of an extended trip. I need something reliable. I might try those Beach Lane. I like that they are black instead of the bright red of the Anderson.
AKNate is offline   Reply With Quote
Old 03-26-2023, 08:20 AM   #12
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
My Anderson’s have survived 3 years of abuse. Used 80+ times. I didn’t need to trim mine.
- Stewart
s1000pre is offline   Reply With Quote
Old 03-26-2023, 08:25 AM   #13
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
Did they break in the arches? I have some made by CARMTEK which work well and are painted black.
JEWare
John Ware is offline   Reply With Quote
Old 03-26-2023, 08:29 AM   #14
AKNate's Avatar
Anchorage , Alaska
Yes. If you stay on smooth, paved surfaces they’re probably fine, but we boondock about 50% of the time and they don’t seem strong enough if you get on uneven surfaces that put some stress on them.
Old 03-26-2023, 09:00 AM   #15
2022 25' Flying Cloud
Northern , Ontario
I have used them for one summer. They are sturdy enough and work well in combination with the LevelMate Pro on a relatively hard surface with a moderate slope. However, I would not recommend them for boondocking.
Aluminium Falcon is online now   Reply With Quote
Old 03-26-2023, 09:45 AM   #16
AKNate's Avatar
Anchorage , Alaska
It looks like LogicBlue, the makers of LevelMate, now make their own levelers. They’re black like I prefer and made in the US. I’ve been very happy with my LevelMate so I might give them a try. The Beach Lane levelers look like they could be decent, but they’re made in China.
Old 03-26-2023, 11:31 AM   #17
reginac's Avatar
Newport Beach , California
I used to have the beech levelers. They lasted three years full timing. I just replaced them with Anderson and these will need to be replaced at 18 months. They don’t hold their shape and now only give a 3inch lift. I will buy beech again.
reginac is offline   Reply With Quote
Old 03-26-2023, 12:32 PM   #18
AKNate's Avatar
Anchorage , Alaska
Our Andersons seemed to hold their shape fine, but they were too brittle. Maybe they softened their plastic to try to counter the breakage issue, but that made them less durable?
Old 03-26-2023, 07:51 PM   #19
Waterloo , Ontario
Damn there's some good info coming out of this thread. Seems like no matter what none of them last "forever" so at least having the lifetime warranty option on a product is a must.
Old 03-27-2023, 06:39 AM   #20
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I had some for awhile and got sold them. We had issues with them sliding on the ground and getting stuck between the tires and frame. Also there was another step involved in getting out of the truck to put the wedge in place.
I went back to 2 x 10 wood boards in combination with a big bubble level. Half way between increments is one board thickness, two increments mean two board thickness. I also keep some 3/4" for getting closer. My system is quick and simple and most importantly my wife understands what needs to be done when we are setting up on a campsite.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Anderson Levelers Stuck Between Tires! TravisH Our Community 39 07-27-2020 12:59 PM
Homemade Anderson Levelers and Chocks jnuechte Airstream Trailer Forums 12 08-21-2018 09:04 AM
Anderson 3604 levelers with 30' trailer with 16" tires? russingr Jacks, Stabilizers, Lifting and Leveling 1 10-19-2016 03:27 PM
Anderson levelers faststart On The Road... 1 09-13-2014 10:05 PM
