Originally Posted by Mollysdad
You can't see the frame. I think what you're using is the vertical mounting support for the axles. That's fine. I'm not sure why Airstream puts the "jack" logo under the trailer with an arrow to a place I guess is the frame.
I'd rather see "Jack" on the axle support plate like you use.
Thank you, I put a 2x4 block on top of the floor jack, perhaps I got lucky and did not collapse vertical mounting support. I will look for the "jack" logo before I check them this year. Thank you, again.
