06-11-2020, 11:04 PM
1963 16' Bambi
1962 22' Safari
Yreka
Advice needed on power tongue jack for vintage
Hello everyone. I am going to ask a question to which all answers will likely be welcome as what information I know I could write on the back of a postage stamp!
We have a vintage, 1963 Bambi. The tongue jack is original and a manual crank. I would like to find an electric tongue jack that would fit as a replacement if possible. Have any of you made this upgrade?
I would also like to know if anyone makes an electric tongue jack that would work on our Airstream Bambi and also have some sort of back up or fail-safe with a hand crank in case power doesn't work due to some unexpected failure.
Any and all advice on this potential upgrade would be welcomed! Thanks in advance.
06-11-2020, 11:50 PM
1980 24' Caravelle
vallejo
hello CaddyGrn, yes it's possible and not to hard. i put a power jack on my 64 Overlander;got tired of the manual jack.many jacks out there. check Amazon/ price about 200$. goodluck. kurt
06-12-2020, 05:13 AM
1972 23' Safari
Middletown
, Rhode Island
All power jacks usually have a back up manual crank function in case the power doesn’t work.
06-12-2020, 05:45 AM
1966 22' Safari
Fredericksburg
We switched out our manual crank with a Reese electric. It has a manual crank if power is lost and an adjustable foot. If I remember, I did have to adjust the three holes a bit but wasn’t a big deal. Sure is nice when leveling, placing jack stands and hooking up with the sway bars. Good luck
06-12-2020, 09:31 AM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
Etrailer has a crank up tongue jack that can be operated with an electric battery drill when you flip the jack handle over. I was going to put one on my 64 Bambi until I sold it.
Antique Pedaler
2021 Caravel 20 FB
06-12-2020, 09:45 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
I believe all eletric jacks have a back up hand crank (no fun when using it but it works) - I think choosing a jack is a personal choice some like jack A others jack B. We use the Lippert Power Jack simply because you can turn the jack head after it's installed so you can drop the tail gate of your truck while attached to the trailer. This was important to us since our F-150 is impossible to get into the bed otherwise.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
06-12-2020, 09:52 AM
1977 31' Sovereign
Peculiar
, Missouri
I bought one from Harbor Freight for my old '78 Land Yacht that had a failure that almost made me cut it off on a trip.
Make sure you find a 25% off coupon, they're in many magazines.
Comes with a crank handle and you can put a socket and drill on it if necessary.
Lee
06-12-2020, 10:13 AM
Tampa
Take a look at how your jack mounts to the A frame.
All current jacks have a standard bolt pattern, (3) 3/8" x 16 bolts on 3" centers.
Electric jacks require a solid connection to the frame, and one 12 ga. wire to the battery.
Every electric jack I've seen has a hand crank, some more convenient that others.
06-12-2020, 10:55 AM
Retired Navy Veteran
1964 26' Overlander
Warner Robins
, Georgia
We have a ‘64 Overlander and purchased a Husky electric jack. At one point the ground was loose and it quit working. Next part is a true story. We took the cap off the top of the jack, unlocked it with the provided key, and then hand cranked the jack up and down. It was so EZ, that I told my wife - “I don’t need no stinking electricity to move the jack anymore“! You guessed it she won the argument again! We liked the Husky so much that we purchased another one for our ‘89 Excella!
As others have said, you have a lot of choices to consider. Read the customer satisfaction comments to assist you in making this decision.
06-12-2020, 11:48 AM
1978 25' Tradewind
1954 15' Byam Holiday
Linden
, Michigan
06-12-2020, 01:13 PM
Mrfixit
Bathurst
, New Brunswick
Hi! Most electric jacks will fit in the old manual jack spot. You usually can also turn the head a different way to clear the tanks or something else on the hitch. They all have the ability to crank manually but some being sold have questionable quality. You get what you pay for. Put one on my 1971 Travelux and had to do a repair when the manual crank nut broke, and had a switch problem. Just a word of caution.
06-12-2020, 04:19 PM
1963 16' Bambi
1962 22' Safari
Yreka
Thanks everyone for the great advice and help! Happy Camping to all!
06-30-2020, 11:03 AM
BALLWIN
, Missouri
I have a Bambi 16' and I installed a Northern Equipment jack, "Eazy Peazy".all the bolt holes aligned and the electric was taken from the 7 way plug ,(which the jack has) to tow vehicle. I have had it for 2 years and NO PROBLEMS.
06-30-2020, 12:03 PM
Tampa
On a vintage trailer, my first concern would be finding one that looked "Period Correct". In other words the Jetson's looking Husky 5000 is not for you.
This?
