Old 02-25-2021, 06:32 AM   #1
dlkershaw's Avatar
2016 22' Sport
Swedesboro , New Jersey
Window leaks ?
I have a 2016 22FB Bambi, No issues since purchase.
I recently noticed a leak around the window behind the kitchen sink.
outside rubber gasket seems to have opened at the corners.
My big mystery is how water ends up on the counter top directly under the window frame.? not much just about a tablespoon full after a rainstorm.
How can water travel from the outer frame to the inner shell ?
anyone developed similar issues?
Best way to service the rubber gaskets outside the window?
Thanks for response: Dave
dlkershaw is offline   Reply With Quote
Old 02-25-2021, 06:41 AM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Rubber gaskets? I don't think I've seen that on my windows - just some kind of grey caulking around the window frames, which when they've leaked I used this to seal the small openings: Captain Tolley's Creeping Crack Cure.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 04-15-2021, 02:00 PM   #3
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Iíve just noticed the same thing on the dinette window of my 2020 Bambi 22FB. Rubber gasket around the outside of the window has popped out on one corner. And water is leaking inside. Pushed the gasket back in but itís still leaking. Be curious to find out how to seal it without a dealer visit.
steilkurve is offline   Reply With Quote
Old 04-15-2021, 04:06 PM   #4
2002 19' Bambi
Lafayette , California
See my reply here: https://www.airforums.com/forums/f45...ml#post2483719.
Tim
Tim A. is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
