Has anyone has this happen? The gasket kind of popped out and is now too big/will need to be shortened or cut. I am wondering about fixing it - should I use some kind of sealant or adhesive? It looks like none was used initially. It's the bathroom window, fixed as in doesn't open.
__________________ Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
That happened to one of our fixed windows on the 55. The outer glazing seal would partially slip out. When I installed all the glass, I sealed it on the inside so we never had any moisture. I did work it back in between the outer edge of the glass and frame. And I also used clear sealant to seal it in place. It hasn’t happened since. I wouldn’t cut it before I tried to work it back into place. Good luck
Thank you so much!
Kim
Charlotte, VT
