Old 02-26-2020, 08:46 AM   #1
1972 27' Overlander
Lamar , Missouri
Water tank access gasket
I have 72 landyacht 30ft and several years ago I replace the interior hose from the water fill spout to the fresh water tank with a new clear hose. During winterization I noticed a layer of dirt down the hose. I cleaned the hose and started to look for the source of the dirt. The access door fit tightly as I had to put pressure on it to close and lock it.
I located the problem during a rain. A strong trickle of water comes from the roof to the window trim then continues to the top of access door. Then the water traveled down the edge of the door into the hinge area and into full area. There was noticable dirt in this area. To remedy, I put a rubber stopper in the spout hole.
Two questions for everyone; is that thin gasket available and anyone else noticed this problem?Click image for larger version
ID:	361926Click image for larger version
ID:	361928Click image for larger version
walleye001 is offline   Reply With Quote
Old 02-27-2020, 08:00 PM   #2
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
That's what I saw when I was leak testing my trailer, I put in a different filler with a screw on cap. it's a big hole to patch over though.
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
Can of beans is offline   Reply With Quote
Replacing MicroPulse tank sensors and tank access on 22FB SilverHouseDreams 2005 and newer - Bambi all models 2 06-20-2018 10:06 PM
Access water pump and fresh water tank??? S. Bade Our Community 1 03-23-2016 02:29 PM
Black water tank termination cap gasket Safari64 Waste Systems, Tanks & Totes 1 10-01-2007 09:37 PM
Fresh Water Tank Access Badco8 Waste Systems, Tanks & Totes 2 03-25-2007 04:34 AM
Fresh Water Tank Access Badco8 Waste Systems, Tanks & Totes 2 03-24-2007 10:22 PM
