Old 12-21-2018, 05:43 PM   #1
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Angry Water leak front top center of trailer
Hi I have a 1993 34' airstream classic.
I have been chasing this front roof water leak at the top of the center window of my airstream for a number of years now. I have sealed every thing I can think of. I even had a sealtech machine on it at a rv repair shop . Was a waste of $250.00.
Sure would like to get my fellow airstream input!!!
Some times you think you found it, but then it shows up at a later time!!!
SOOOOO frustrating!!!
THX BILL
william Haym is offline   Reply With Quote
Old 12-21-2018, 06:37 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
There is a lesser known o ring under the rotation point of the Wingard antenna. These fail and provide a huge leak point. .06 cents and the leak is gone.
Old 12-21-2018, 07:11 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I had the antenna "O" leak starts as a drip and ends up as a serious leak.
I never could find an O ring to totally seal so I ended up buying a new shaft with the O ring around $10.
I also an air vent for the sink leaking there is a gasket kit to repair. The leak was hard to find as the leak was over the door several feet away from the vent.
Garry
Small black antenna-on top-front and center R2DTube Electronics & Connectivity 11 05-20-2018 06:08 AM
1973 Airstream Top Front Center Panel Silver84 Airstream Classifieds 0 12-28-2016 06:36 AM
Leak from front awning top mount? Ohiobrits 2011 - 2015 International 10 09-17-2016 09:52 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Frustration !!Water leak at front of trailer!! william Haym Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-06-2011 11:41 AM
