RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-27-2020, 10:44 PM   #1
2013 16' Sport
SEATTLE , Washington
Water intrusion?
We are on our first trip with our newly acquired 2013 Bambi. When we were setting up at camp we noticed a soft spot in the floor near the fridge and dining seating area. Tonight it is raining for the first time on our trip and there is water coming in from underneath the fridge. I did also do dishes however the plumbing is dry, as is the inside of the fridge, and there wasnít the same issue when I did dishes yesterday.
Iím worried because we are in the Pacific Northwest where there is no shortage of rain, and itís not going to be parked in a covered area.
A couple questions:
How concerned should we be?
Is there anything we should do in the immediate moment other than roll up a towel and place it under the fridge?
Is this sort of thing likely to be covered with warranty, which I purchased / took over from the private seller?
br00ksie is offline   Reply With Quote
Old 11-28-2020, 12:58 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Depends on what your warranty covers. Youíre out of the manufacturerís warranty so you have some sort of third party one now.
You can go to the outside and check the compartment that vents the fridge. See if somehow water is getting in from there? You may also have a roof vent that may somehow be getting water in. Both may be as simple and depend how the trailer is leveled?
If youíre handy, itís not difficult to take the fridge out and look at everything. Mine was 4 screws, two bolts, and disconnect the electric and propane. You need to determine if this water is coming from the outside, some sort of water line broke (which doesnít look to be the case) or if the fridge is just leaking water either from going bad or the drain line in back is not draining to the outside.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Water Intrusion CNorm Sprinter and B-van Forum 4 11-24-2020 08:46 AM
Water Intrusion CNorm Forum Admin, News and Member Account Info 0 11-22-2020 01:45 PM
Rear Water Intrusion junebug76 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 02-20-2019 06:48 AM
Water intrusion at rear bumper - What years affected? RFP Repairing/Replacing Floor &/or Frame 44 06-28-2018 03:02 PM
Water Intrusion lukeysh714 2016 - Current Classic (all lengths) 20 11-21-2017 09:36 AM
