04-30-2021, 03:38 PM
2020 23' Globetrotter
San Francisco
Vent dripping water - is this a problem?
We've been full-timing for ~8 months, but only now are dealing with hot weather (90+ in Arizona). With the AC running all the time, this vent is now dripping water. I have no idea how concerned to be. Anyone know?
Thanks!
Dave
04-30-2021, 04:48 PM
Sag Harbor
, New York
You might want to check for leads in the sub-forum which includes the air conditioning IMO:
https://www.airforums.com/forums/f427/
Good luck,
04-30-2021, 06:49 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
Your drain line might be plugged. You can blow it out with compressed air
04-30-2021, 06:52 PM
2012 25' FB Eddie Bauer
Virginia Beach
Or suck it out with a wet/dry vacuum. Less likely to spit dirt all over the interior.. You should find the drip hose in the roadside wheel well.
05-01-2021, 11:19 AM
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
While you are at it, you probably should clean the filters and pull any dust out of the ducts. Even if it's not the cause, it's something that needs doing fairly often.
05-01-2021, 02:36 PM
2012 23' FB International
Woodstock
Is it possible that the cooling coils are frozen from humidity overload. Water will then build up in places where it can’t drain properly . This is usually accompanied with poor cooling
Shut off the AC when you leave the trailer and let it defrost. If the water only comes back after running for a while the problem may be the the AC can’t handle the high humidity
JCW
05-03-2021, 09:42 AM
San Francisco
Thanks everyone. Anyone know where the drain line actually is for this? Think I'll first try this approach and see if it works; I unfortunately don't have easy access to a wet/dry vacuum
05-04-2021, 10:40 AM
San Francisco
Is this the AC drain line? To blow this out, I basically just connect my air compressor to it and try to create a vacuum seal?
05-05-2021, 05:38 AM
Woodstock
Yes
JCW
