We've been full-timing for ~8 months, but only now are dealing with hot weather (90+ in Arizona). With the AC running all the time, this vent is now dripping water. I have no idea how concerned to be. Anyone know?
While you are at it, you probably should clean the filters and pull any dust out of the ducts. Even if it's not the cause, it's something that needs doing fairly often.
Is it possible that the cooling coils are frozen from humidity overload. Water will then build up in places where it can’t drain properly . This is usually accompanied with poor cooling
Shut off the AC when you leave the trailer and let it defrost. If the water only comes back after running for a while the problem may be the the AC can’t handle the high humidity
JCW
Your drain line might be plugged. You can blow it out with compressed air
Thanks everyone. Anyone know where the drain line actually is for this? Think I'll first try this approach and see if it works; I unfortunately don't have easy access to a wet/dry vacuum
