RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-15-2017, 06:10 PM   #1
1974 31' Excella 500
Livingston , Texas
Using Automotive Windshield Adhesive to glue Vista View windows back in
I have a '74 Excella. The Vista Views have had the interior plastic lens removed and only the glass is left. They are the kind of VV's that have the snap ring on the interior of the opening.
I have searched countless threads on the proper sealant to use to adhere the glass to the inside of the aluminum frame (Vulcem, Sikaflex, TremPro, etc.). Sikaflex was used about seven years ago to adhere the glass to the frame, but a number of the VVs are now leaking at the glass/metal junction (not the outside of the frame. Some VVs have even separated from the metal frame altogether.
Before I use Sikaflex again to reattach the windows...
Today, it was recommended that I use a urethane Automotive Windshield Adhesive (like 3M #08693) to attach the glass to the inside of the metal frame. At first blush, it sounds like a brilliant idea - cars endure the same road conditions as Airstreams, and (although its possible) I've never seen a glued-on automotive windshield separate on its own from the metal structure it is attached to, or leak, (like my Vista Views do).
Any thoughts on using a urethane Automotive Windshield Adhesive for this job?
Thanks, Heinz
Link to 3M Adhesive: https://www.oreillyauto.com/detail/3.../08693/4462151
H.Huester is offline   Reply With Quote
Old 01-14-2018, 12:23 AM   #2
nickclifford's Avatar
1972 31' Sovereign
felton , California
I've got a similar issue after recently removing the old plastic Perspex interior window pane. Maybe the leak was there before and I never realized? But dont see that possible. i don't see how removing the inner pane that sat in its own channel could now cause the vista window to leak? sure if it's sealed from the outside properly, rain water couldn't get through.
nickclifford is offline   Reply With Quote
Best Adhesive for Glue Down Cork Flooring Alsupp Floor Finishes 7 07-15-2015 04:56 PM
Glue or not to glue carver 1 Floor Finishes 15 06-15-2015 07:12 AM
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 10:08 PM
Solid Vinyl Tile (SVT) Adhesive Glue ? trevisgardne Repairing/Replacing Floor &/or Frame 2 04-14-2006 11:04 PM
