Old 11-05-2018, 08:23 PM   #1
State College , PENNSYLVANIA (PA)
Trying to find a leak
We have a 2013 25FB. Noticed a small leak in the front bedroom under the streetside window along the floor. I have picked away at the obvious locations with Sikaflex and Captain Tolley's. I have sealed the exterior of the window, awning bracket, both side marker lights (top and bottom), middle and lower trim, front windows, and stone guard brackets. I also hit all the rivets in the vicinity with Capt Tolley's.
The leak shows up under the window and I placed a level where I see it on the interior. I looked at the two rivets holding the International emblem on and placed a hose there for several hours and it remained dry so I don't think that's it.
Pressurizing the trailer with a sealtech unit didn't show anything. Rather than seal everything in that area at once, I have been picking off items one at a time in hopes of finding exactly where the leak is.
I have checked the side window seal but there doesn't appear to be any water getting past the glass and the seal because I'm not seeing any water laying in the trough at the bottom of the window.
I have not touched the awning or solar on top of the trailer but have been over those areas and nothing sticks out as being an issue. I sprayed a hose over the top of the trailer over the weekend and it remained dry.
Today we had a pretty good shower all morning. Checked the interior before work and it was dry but when I got home there was just a little water. Any suggestions on what to try next?
GSP9 is offline   Reply With Quote
Old 11-05-2018, 08:48 PM   #2
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I've had leaks at:
the caulk on the horizontal bands
the caulk at the perimeter of the roof fan frame/curb.
the skylight, cracks in the flanges from fasteners overtightened
the joint between end cap and wall at the end of the awning.
the awning arm where screws penetrate the wall
the marker lights, at fastener and wire penetrations.
Alan
Old 11-14-2018, 04:26 PM   #3
J.Denmark's Avatar
2018 27' International
Charleston , South Carolina
Hi GSP9, I hope you got your issue fixed and I know this may be kinda late to the game but we just had a repair done on our unit that was leaking in the same window area, though on the opposite side. The dealership did a pressure test and it turned out that we had one leak at the running light and one at the awning support, both on the same side. They repaired it and retested it several time to validate the repair.
J.Denmark is offline   Reply With Quote
Old 01-02-2019, 03:37 AM   #4
Sol
ItchyFeet
Sol's Avatar
2017 25' Flying Cloud
Fuquay Varina , Wake County
How do you do pressure test? I don’t think all dealerships have capability of pressure test.
Sol is offline   Reply With Quote
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Trying to find a trailer article on here keith53 Airstream History 2 06-23-2011 08:54 PM
Trying to find a lens cover for a 2007 Bambi gqmmom 2005 and newer - Bambi all models 2 07-11-2010 09:31 AM
Trying to find shower curtain for '93 Excella ghilliedhu1 1990 - 1993 Excella 3 09-05-2009 02:57 AM
Trying to find aluminum caulk Bluto Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 05-28-2009 09:09 PM
