Old 06-17-2018, 04:06 PM   #1
1962 19' Globetrotter
2001 31' Excella
Tracking Rear Leak
I found a pretty significant leak - likely worsened by the carpet and pad that are there - in the rear compartment. I know the rear bumper is notorious for causing leak problems, but I’m not sure that’s my problem. The bumper does slope towards the trailer, but seems to curve down where it meets the body, so I think the water at least drains away and not into the trailer. Curious if anyone with this type of bumper and rear compartment has found the same issue and what they did?? I’m a 2001 Excella. Click image for larger version
Craig is offline   Reply With Quote
Old 06-26-2018, 09:20 PM   #2
gator.bigfoot's Avatar
KW , Ontario
Originally Posted by Craig View Post
I found a pretty significant leak - likely worsened by the carpet and pad that are there - in the rear compartment. I know the rear bumper is notorious for causing leak problems, but I’m not sure that’s my problem. The bumper does slope towards the trailer, but seems to curve down where it meets the body, so I think the water at least drains away and not into the trailer. Curious if anyone with this type of bumper and rear compartment has found the same issue and what they did?? I’m a 2001 Excella. Attachment 314267Thanks!
I've got the same issue. Not sure where it is coming in.
gator.bigfoot is offline   Reply With Quote
Old 06-27-2018, 08:53 PM   #3
KW , Ontario
I found the leak. Coming in from bottom corner of hatch door frame where the hinge is under the frame. Looks like it was never sealed. I opened up the inside by drilling out the rivets and removing the insulation under the hatch door. Now I just have to get the sealant and put everything back.Click image for larger version
ID:	315330Click image for larger version
Sent from my SM-N950W using Airstream Forums mobile app
Old 06-27-2018, 09:22 PM   #4
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Good news, your bumper is not the type that causes the through wall leak problem, if the cover is not cracked. The fiberglass bumper cover turns upward at the wall. (same as my 99 Excella)
Alan
Old 05-06-2019, 07:35 PM   #5
2001 31' Excella
Tracking Rear Leak
A W - do you have any pics or know where I can find a diagram or something to show how the bumper turns upward? I hate to remove the rub rail just to see it.
Old 05-06-2019, 08:57 PM   #6
dznf0g's Avatar
Oswego , Illinois
I've never seen a pic of it, but I saw a classic on the line just as they were about to place the bumper and end wraps on. They were on the floor. All 3 pieces curve up about 1/2", up under the lower extruded molding. The only way water can get past would be the joints between the center fiberglass piece and each end wrap
I've been battling leaks which appear at the compartment door corners fo a long time. I am right now reworking the window. Found some moisture behind the license plate pocket, indicating origin is up north. I removed the awning, in part to replace the fabric awning key. There were some suspect areas at the window top which could only be seen with the awning removed. I am too experienced to claim victory until some time and rain passes.
-Rich-
Old 05-06-2019, 10:24 PM   #7
A W Warn's Avatar
2000 25' Safari
this is the center piece, not a very good photo
https://airstreamsupply.com/BUMPER-REAR-CENTER-203142
Alan
2005 model year quality tracking..... Silvertwinkie Airstream Trailer Forums 295 10-01-2007 11:51 AM
Tracking down a leak.....window?? Captmorg Windows & Screens 8 10-22-2004 12:13 PM
Patent Number tracking HELP roadeo Off Topic Forum 2 08-09-2004 02:39 PM
Bathroom Door Tracking Out Of Alignment montanaandy Doors & Locks 2 07-12-2003 03:47 PM
Tracking history Diana Langley Off Topic Forum 3 06-23-2003 07:55 AM
