Old 07-03-2018, 09:09 PM   #1
2008 20' Safari
Fonthill , Ontario
Unhappy Tear/Crack under rock guard bracket
Hello all,
We did a thorough look at the airstream we just purchased and it looks like there is a minor crack in the aluminum, where the rock guard attaches. Is there a more cost effective easy way to fix this (without replacing the panel)? We were thinking maybe silicon?
Please let me know your thoughts! Advice is welcomed and much appreciated.
StreamingB is offline   Reply With Quote
Old 07-03-2018, 09:27 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Maybe you could drill out the end of the crack to stop it and then aluminum braze it. Prob not but itís a thought.
Old 07-03-2018, 11:04 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Since it's in a hidden location:
Remove the bracket.
Drill a hole in the end of the crack.
Fill the hole with Vulkem or similar.
Cur a patch out of aluminum, and rivet it over the affected area. Make sure the patch is an inch bigger than the crack.
Rivet the bracket back in place on the patch.
Apply sealant as required.
Re-install the segment protector.
Front Curbside stone guard -Front Sun guard Projet2907 Windows, Doors, Locks & Vents 0 02-06-2018 07:26 AM
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 03:00 PM
2015 FC torn skin behind rock guard bracket MichaelSTR General Repair Forum 12 08-27-2016 08:30 AM
Crack in Center Rock Protector TinTin General Repair Forum 3 04-02-2015 07:40 AM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
