Old 09-03-2019, 02:59 PM   #1
Lthrncktrvlr's Avatar
2004 34' Classic S/O
Independence , Kansas
Suspicious leak
Over the weekend, I noticed an intermittent leak on my 2004 34' classic s/o from a weep hole in the center of the black and gray tank bottom cover. It was only sporadic and suds/bubbles formed on the ground. No odor, clear, intermittent. Not looking forward to dropping that cover so wondered if anyone had experienced this and knows already what's up?
S/OS #069
2004 Classic LTD 34' SO Sofa
2015 Ford F350 SRW
Lthrncktrvlr is offline   Reply With Quote
Old 09-03-2019, 04:15 PM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Suspicious leaks are the worst kind.
I own a class b not an AS trailer, so just tossing out the question of did anything unusual precede this event. Full tanks, rough road, sewer smells inside, right after a dump?
rowiebowie is offline   Reply With Quote
Old 09-03-2019, 04:56 PM   #3
Well I noticed it during a dump, and it was getting close to 3/4 full, the bathroom had a slight odor but I attributed it to having the exhaust fan on and it pulling air up from the floor. No rougher roads than normal.
S/OS #069
2015 Ford F350 SRW
Old 09-03-2019, 06:00 PM   #4
rowiebowie's Avatar
2012 Avenue Coach
Hopefully, that information will help your fellow trailer owners. I'm hoping it is something simple like a valve or hose connection that needs attention.
Good luck.
Old 09-04-2019, 07:30 AM   #5
rowiebowie's Avatar
2012 Avenue Coach
Giving your post a bump. Any leakage while it sitting after your trip?
Old 09-04-2019, 08:10 AM   #6
Thanks and no further leakage, I should have taken some photos.
S/OS #069
2015 Ford F350 SRW
Old 09-18-2020, 12:10 PM   #7
flynmike's Avatar
2005 30' Classic
Sacramento , California
I had a suspicious leak that was intermittent for years. I've had my '05 Classic for 15 years (since new) and water would settle in to the area where the city water and tank flush hook ups are. Sparing you all I went through, it turned out the city water hook up fixture was faulty and replacing it solved the problem! It would only leak at higher water pressures. Frequently RV park water pressure is not great so it didn't leak then. It leaked when I used the pump and the pump cycling caused me concern. Very frustrating but easily fixed.
'05 30' Classic rear queen with an '11 Dodge Cummins Turbo Diesel tow vehicle
Avatar is inflight refueling of an F-15 over Nevada...best job ever!
flynmike is offline   Reply With Quote
Old 09-18-2020, 04:45 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Had a similiar leak two seasons ago on "Cloudsplitter".
It took 15 years but the overtightened clamp finally cracked the flange for the grey tank valve. 👎
Cut an access hole in the pan and replaced it.👍
ID:	378946   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 09-18-2020, 08:22 PM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
Fill both black tank and grey tank with water. Put a different color food coloring in each. Sit a pan under the place you saw the leak and wait.
I did it trying to diagnose a leak. I ended up finding the tank to valve adapters cracked on both tanks.
CRH is offline   Reply With Quote
Suspicious tow ratings Antique Pedaler Tow Vehicles 3 04-01-2007 10:38 AM
Suspicious EBAY Listing?? FiveOJoe Off Topic Forum 4 05-16-2006 08:19 PM
Suspicious eBay listings Cedars Off Topic Forum 4 02-12-2006 03:12 PM
