Skylight area leak....
We had a partial roof reseal on our 2015 FC this summer as part of the standard annual maintenance and as fate will have it we now we have a rain water leak coming from the skylight area. In checking the partial reseal I see they have applied sealant to the Fantastic fans but not the skylight. Removing the inside skylight trim I get quite a bit of extra water coming through that was trapped in the trim channel. A week ago I made a repair and got on the roof and applied copious sealant and tape and reworked all the skylight edges and ran sealant tape from the side of the skylight down to the roof surface and thought that I did quite a pretty good repair job.... until this evening. After a day of light rain, water appears in the same location, kitchen side of the skylight and also comes out of the seam halfway between the skylight and the kitchen cabinet. Since we have the AS model with the air conditioning double roof duct I'm beginning to suspect that the water is entering the roof at another location and running inside the roof till it finds a way out via our skylight trim. The air conditioning unit is my next suspected entry point but I wanted to check in with AirForums and see if this has been a problem for anyone else? Being a former boat owner I know with water leaks there are plenty of surprises!
David & Margaret Broad
2015 25’ Flying Cloud
2015 RAM 2500 Laramie Cummins
WBCCI # 2381
