I realize there are a bazillion sealing threads...
Skins are off. This summer's rains have revealed only a few seams/areas that need attention.
I have that black sprayed gunk that someone said was tar. So I plan to strip it in the problem areas and put something else in its place. There are also several places where Airstream just decided not to spray --like under the windows-- that will receive some goo of their own.
But the rest of the interior is pretty dry.
I'm in the if-it's-not-broke-don't-fix-it camp. There's enough to do on this trailer without adding another project (of stripping all the tar and re-sealing all seams).
And yet, the walls are right there, easily accessed...
From my reading, it seems like most sealants need careful preparation for long-term adhesion and some of them are not recommended for enclosed indoor spaces. Even the prep solvents like acetone or brake cleaner are supposed to be used in well ventilated areas.
The quandary is: Should I do something to the remaining seams? Is there anything out there that would stick over the tar gunk that is currently on the interior walls?
Which of the many sealants out there (Lexel, Parabond, Tempro 635, Sikaflex 221, Gutterseal, Eternabond, Vulcum (did I miss any
?)) can actually be applied inside?
Which will stick against gravity on less-than-ideally prepared surfaces?
