Old 03-29-2020, 06:39 AM   #1
Cispook's Avatar
2020 22' Bambi
Chillicothe , Arizona
Sealant
I read (not sure where ... old age) that the factory standard in sealer is now Adseal Premium.
Anyone use same - during our current stay home period I am going to check the roof etc and do some resealing.
Regards to all
Cispook is offline   Reply With Quote
Old 03-29-2020, 06:46 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Adseal isn’t what the factory is using.
I prefer Alpha-One 1021 for the roof and Sikaflex221 “gray” for the rest.
Old 03-29-2020, 06:59 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
I'm just a jaded GOF, but after 35yrs of Streaming I tend to suspect the OEM choices for various products used.
I have used...👍
I currently use 4200 for most sealing and 5200 for permanent applications.
ID:	364205   Click image for larger version
Obrigado, é hora de descansar.
Tahawus
Old 03-29-2020, 10:21 AM   #4
Cispook's Avatar
2020 22' Bambi
I don’t recall where I read or heard same ... I did look at the AS online store and they have an AS seal/caulk kit that has AdSeal and it’s labeled for two colors along with two other sealants.
Not saying your wrong as they offer the other common sealants as well.
Changing times?
Old 03-29-2020, 10:23 AM   #5
Cispook's Avatar
2020 22' Bambi
I have used...
I like the 4200. Any tips?
Old 03-29-2020, 10:29 AM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Changing times?
Sorry typo. Adseal. “IS” what Airstream uses
Old 03-29-2020, 10:33 AM   #7
batman's Avatar
1964 22' Safari
modesto , California
Regards to all
There is a comprehensive thread on the subject.
https://www.airforums.com/forums/f45...ry-116214.html
-Dennis
batman is online now   Reply With Quote
Old 03-29-2020, 12:06 PM   #8
The 4200 is the 'quick' cure, but give it at least 24hr to set before working around it.
For smooth surface bonding course sand the surfaces.
For sealing, clean well and let cure completely.
Tahawus
Old 03-29-2020, 01:19 PM   #9
Cispook's Avatar
2020 22' Bambi
No worries - I have plenty of mistypes
Old 04-04-2020, 04:18 PM   #10
snappykelly
snappykelly's Avatar
1986 25' Sovereign
North Bend , Oregon
Im sorry. what brand is the 4200? Thank you.
Kelly
Kelly Barnett:
snappykelly is offline   Reply With Quote
Old 04-04-2020, 06:26 PM   #11
Kelly
MMM
Do the amazon.
Tahawus
Which Sealant Where? Jabba Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 02-05-2007 08:03 PM
Sealant for furnace intake/exhaust plate lbf78SvgnInt31 Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-08-2004 09:55 AM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
sealant Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 11-06-2002 08:41 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
