Old 01-16-2018, 08:14 PM   #21
1981 31' Excella II
New Market , Alabama
This plate has ruined 1000's of trailers. Remove rub rail then caulk. Check for floor and frame damage. Pull belly skins to see what is going on in there. This is the major cause of rear end separation.
Perry
Originally Posted by nickclifford View Post
Attachment 302490
I️ read here that itís best to remove the trim to seal properly. This was done a few years back. Iím thinking itís possibly one of the rub rails. Waiting for rain now and I️ did a bunch of sealing over the weekend.
Water can get through the hinge plate hinges though , if that make sense ! But just flows into the storage area. Assuming designed like this originally. Attachment 302491
Old 01-16-2018, 09:54 PM   #22
nickclifford's Avatar
1972 31' Sovereign
felton , California
Rub rail trim , Should these be sealed ?
Perry
Yeah, such a shame, only reason this trailer has survived is that it resided in the southern Cali desert for much of it's life. The rear flooring as survived except for the extreme outer edges. One side is showing signs of slight movement but in the scheme of things I'm not worried. I've pulled the rub-rail off and caulked. I suspect water was getting in from somewhere else too. Waiting for the next rain ☔️ now.
nickclifford is offline   Reply With Quote
Old 04-05-2021, 10:49 AM   #23
Dkoelfgen's Avatar
2011 27' FB Flying Cloud
Albertville , Minnesota
27' Flying Cloud Rub Rail loose.
2011 27 Flying Cloud Rub Rail coming loose on the left (Road) side.
Has anyone seen this before?
The heads of the screws popped off and the Rub Rail is pulling away from the body. Wondering if this indicates problems elsewhere or could it be from water getting behind and freezing?
Dkoelfgen is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Rub Rail Trim JudgesArgosy Argosy Motorhomes 11 01-26-2013 09:43 AM
Rub Rail aka Body Trim aka ??? ukinusa Ribs, Skins & Rivets 3 02-16-2011 05:42 PM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
