Old 06-05-2020, 09:56 PM   #1
1995 19' "B" Van Airstream 190
Lehigh Acres , Florida
Roof leaks
Can someone recommend a good sealant/chalk for repairing a leak on my 95 B190 motor home?
BruceLuh is offline   Reply With Quote
Old 06-05-2020, 10:23 PM   #2
2018 25' International
Slidell , Louisiana
I like Silkaflex 221. It is a bit less sticky and easier to apply than what Airstream recommends but have noticed the white tends to yellow......
Old 06-06-2020, 05:51 AM   #3
2019 30' Classic
New Milford , Pennsylvania
3M5200 works well. Do it right the first time as it is nearly impossible to get it off.
AKmtnpilot is offline   Reply With Quote
Old 06-06-2020, 06:37 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Ummmm, not me. 3M 5200 is more of an adhesive than sealant and you are right, it is permanent. I'm not sure I would use it even if I were building a new trailer and overlapping aluminum panels. There are quite a few threads on the forum about sealants and where to use them. I am a proponent of 3M tape on the roof seams.
Larry
lsbrodsky is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
