Old 07-08-2018, 04:49 PM   #1
Wconley's Avatar
2018 28' International
Renton , Washington
Rear Bumper Leak - Another Repair Complete
I know this has been covered many times but since I was very nervous stepping in to fix this myself, I thought I would share my fix for those that feel like I did. First of all, this fix is relatively easy if all you are doing is stopping the leak. I don’t have any floor soft spots so stopping the leak was my main goal. I’m uncertain when this manufacturing practice started but I read that in 2012 Airstream corrected it.
I picked up a moisture meter and did some tests to confirm that moisture content was higher under our dinette at the rear of the trailer so I knew I needed to fix it as soon as I could. After reading many of the posts on this I decided to dive in.
1) As you can see in the first picture there is absolutely no sealant between the beltline and bumper lid. Remove the Center Chrome strip. It is some sort of firm rubber that is held on with surprisingly little stick from double sided tape. Then remove the screws holding the belt line on. These were in pretty firm and I found it helped to use my small impact driver and a new screw driver head. These can be held back easily to get access to the repair.
ID:	316330   Click image for larger version
ID:	316332   Click image for larger version
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 07-08-2018, 04:51 PM   #2
Wconley's Avatar
Renton , Washington
2) Now you can see that the bumper compartment lid is completely unsealed where it meets the rear wall allowing any water on the lid to flow into the rear floor area. Insult to injury, my trailer also had two areas where the gap between lid and rear wall was as much as 1/4” by 6” or so long at each end of the bumper compartment. In the picture you can see where a putty knife could slide about 4” into the gap.
ID:	316334   Click image for larger version
Walt
2013 F150 Ecoboost
Old 07-08-2018, 04:54 PM   #3
Wconley's Avatar
Renton , Washington
3) I chose to get some 1/2” x 1/2” aluminum flashing to help seal this area as well as some rubber seal material to help fill the gap. About $6 at Lowe’s. To match the curve at each end of the bumper compartment I cut on the bottom flange approximately every two inches so I could shape the flashing. I added a bead of Sikaflex to the backside of each flange and then pop riveted it into place. I then sealed all edges of the flashing. Note that I had picked up white Sikaflex by mistake but since this would be hidden I completed this step with what I had. Gray Sikaflex was used for all exposed seals.
ID:	316336   Click image for larger version
Walt
2013 F150 Ecoboost
Old 07-08-2018, 04:57 PM   #4
Wconley's Avatar
Renton , Washington
4) Rienstall the beltline just like you removed it. I opted to go with new screws although the old screws would have been fine. I then used 1” wide two sided exterior tape to reattach the center trim.
5) I masked off the areas to be sealed because Sikaflex is quite tacky as it comes out of the caulking gun and sticks to everything. This also gives me a chance of getting a nice caulking line. This worked quite well but I found that the blue painters tape pulled some of the gray paint from the bumper compartment lid and some of the chrome from the center trim.
With the exterior seal, the flashing seal and the bead under and behind the flashing I have three seals keeping water from entering the trailer at the bumper. It probably took me four hours or so to complete since I was taking my time. Someone else I’m sure could do it in an hour or so if they knew what they wanted to do. I think it’s very important for someone with a trailer that might be affected by this leak to investigate it with a moisture meter and make appropriate repairs to minimize future repairs and expense. I hope this helps people like me that are nervous about diving in.
ID:	316338   Click image for larger version
Walt
2013 F150 Ecoboost
Old 07-09-2018, 12:14 PM   #5
CAV
CAV's Avatar
2004 25' International CCD
Dubuque , Iowa
Nice job! Great tutorial. Did you attempt anything to treat wood behind wall? Thx
CAV is offline   Reply With Quote
Old 07-09-2018, 06:12 PM   #6
Wconley's Avatar
Renton , Washington
CAV, no I didn’t try to treat the flooring wood. I’m not sure how I could do that without pulling the dinette, couch and vinyl. Since I don’t detect any soft spots I didn’t want to do that at this time. Maybe others with more experience could weigh in on options.
Walt
2013 F150 Ecoboost
Old 07-09-2018, 07:52 PM   #7
Albuquerque , New Mexico
Thanks for sharing your tutorial. This is a preventative fix I plan to carry out on my 2005 Safari 25.
Airhead59 is offline   Reply With Quote
Old 07-09-2018, 08:15 PM   #8
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
I recommend at a minimum dropping the belly pan enough to slit the reflectix insulation in the back two panels to let water out. I cut it out completely and pulled the furniture/floor up to dry and then treat the floor. If the floor is solid then you might only need to let the existing water drain so the floor can slowly dry out.
Here's my story. I have a 2008 27FB.
http://www.airforums.com/forums/f396...ml#post1262866
SuperTrouper is offline   Reply With Quote
Old 07-09-2018, 11:16 PM   #9
Wconley's Avatar
Renton , Washington
Thanks SuperTrouper! I hadn’t found your write up when I was reserarching and wish I had. Than may be my next step - I may give it time to see how much it dries.
Walt
2013 F150 Ecoboost
Old 07-10-2018, 12:12 AM   #10
Yeah, note that I fixed the leak in January and the water was
Still in the floor in August when I took further action. I hope that yours dries faster but unfortunately with vinyl on top and plastic below, it’s not likely.
Old 07-10-2018, 07:05 AM   #11
heslinhotel's Avatar
1989 29' Excella
1999 25' Safari
Youngsville , North Carolina
I have owned 6 TT by Airstream, 2 Argosy and 4 Airstreams ranging in age from 1974 to 1999. Everyone has had this issue, the first thing is ALWAYS Caulk the beltline. This area where side meets belly is overlaped backwards and funnels water into joint with floor.
heslinhotel is offline   Reply With Quote
Old 07-11-2018, 12:01 AM   #12
Adiredneck's Avatar
2014 27' FB Classic
Cambridge , New York
Images: 8
I've had the same problem with my 2014 27FB Classic. I took it to Foleys, and they pulled up the floor and caulked the rear bumper area in January; but when I took the trailer north on a long trip in May through heavy storms, I noticed that the back was all wet again. Not sure where/how they caulked it, but it seems I better do the job myself this time. So much for Airstream correcting the problem in 2012!
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 07-11-2018, 06:42 AM   #13
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Great write up. Thanks for posting. I have a 2011, so I imagine I’m needing to do this. I bought a moisture detector, but haven’t found moisture in the floor and no soft spots. Our AS does sit under cover though. I have the rear bath in our 23, so there’s no way to get the moisture detector near the back wall.
I still think I’ll do this repair. Four hours work for peace of mind.
Thanks again for sharing
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
GettinAway is offline   Reply With Quote
Old 12-30-2018, 03:34 PM   #14
2005 16' International CCD
LAFAYETTE , Colorado
What is a good adhesive to reattach the vinyl trim to rub rail?
TYSON PECK is offline   Reply With Quote
Old 12-30-2018, 03:35 PM   #15
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Originally Posted by tyson peck View Post
what is a good adhesive to reattach the vinyl trim to rub rail?
3m vhb
Old 04-14-2019, 09:05 AM   #16
RichHog's Avatar
1972 23' Safari
Houston , Texas
Great thread that ALL owners of trailers in this age group should know. Tore out the flooring on mine and rotten wood before getting it resealed.
RichHog is offline   Reply With Quote
Old 09-03-2019, 11:49 AM   #17
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Don't want this to sound flippant, but why wouldn't a good caulking seal between the bottom of the beltline and the bumper cover plate (which are less than a 1/4" apart) not be sufficient to prevent the water from getting under the beltline which would then simply drain to the ground on either end of the bumper plate? One would also caulk the top portion of the beltline to prevent water from entering from that side.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 09-03-2019, 01:22 PM   #18
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
That’s exactly what I did.
sheriff1 is offline   Reply With Quote
Old 09-03-2019, 03:23 PM   #19
1981 31' Excella II
New Market , Alabama
Just going to leave this here. This permanently fixed the problem.
http://www.motorcycleproducts.org/AS...Rear-skins.jpg
Perry
Leak at rear bumper storage rotted floor inside A W Warn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 60 09-01-2018 10:47 PM
Permanent fix for rear bumper leak DJCJ 76 AIR Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 04-26-2013 08:15 AM
2004 Safari rear bumper leak swede0030 General Repair Forum 4 08-06-2012 04:31 PM
C Channel - Floor - Famous Rear Bumper Leak Soyboy Repairing/Replacing Floor &/or Frame 9 08-08-2010 06:57 AM
Another trip, another repair swanky Classic Motorhomes 6 07-07-2009 03:24 PM
