Old 06-01-2017, 06:13 AM   #1
1965 30' Sovereign
Lake Orion , Michigan
Quick Leak question
Is it possible based on the internal structure that the awning rail leak could show up at the front window? Could it be running along some of the framing and end up there? Any thoughts? Thanks.
I sealed the running lights, the rock guard and the front gutter. Still leaking above the window. I am at a loss.
Any help is greatly appreciated
mmollema is offline   Reply With Quote
Old 06-01-2017, 06:49 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
There is no internal connecting structure between the awning rail and front window frame to provide a water path. The endcap segmented panels have no internal structure, they are self supportive.
Old 06-01-2017, 07:06 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Where on the window is the leak showing up? I can guess pretty close from your description, but it's only a guess.
Old 06-01-2017, 08:18 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
...but they can leak all by themselves, and the water will follow the seams, and pop out right around the front window area. I would suggest using par-bond on all of the seams in the end cap. On mine, there is this one small little "wave" in the edge of one of the panels...very slight, hardly noticeable up close, but it actually created a substantial gap where water could (and did) penetrate.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-01-2017, 08:23 AM   #5
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Could be from rivet lines from the end cap. I had a leak at my rear window that ran down the bug screen. I have an opening in the rear of the cabinets for the audio equipment and its dry as a bone above the window frame.
If you can reproduce the leak by mounting a hose sprayer on a ladder and pointing it to the window that will a big headstart to solving the issue. If the window doesn't leak then move the hose sprayer higher up.
I used duct tape to tape off suspected areas of leakage then tested again with the hose to confirm.
I was lucky I could reproduce the leak after 20 minutes of running water.
Kelvin
Old 06-01-2017, 09:02 PM   #6
1965 30' Sovereign
It's not the window it's not the rock yard it's leaking above the window and I can put my finger above the molding and feel the water I resealed the running lights thinking that might be a problem I don't see any gaps in the lap seams.
Old 06-01-2017, 10:37 PM   #7
Journeyman
2016 25' International
Deerfield , Massachusetts
True... but there is insulation in the wall that could be forming some sort of aqueduct...
thiel is offline   Reply With Quote
Old 06-02-2017, 04:38 AM   #8
Boxite's Avatar
2008 22' Sport
What about your AM/FM antenna? Television Antenna? Skylight? etc.
quick question 1967 Overlander ren walker Our Community 9 01-09-2007 10:10 AM
quick question on aluminum cutting wannaroam Ribs, Skins & Rivets 15 01-01-2007 07:23 AM
Quick boondocking question.... Kestrell Water Heaters, Filters & Pumps 8 07-30-2005 08:20 PM
Quick 12v Question Dave-O Electrical - Systems, Generators, Batteries & Solar 8 03-05-2003 03:37 PM
quick question is it a 77 or a 76 overlander Our Community 23 10-03-2002 07:21 PM
