Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-15-2019, 12:55 PM   #1
2018 25' Flying Cloud
Comox Valley , British Columbia
Persistent water leaks
Hello
We own a 2019 Flying Cloud 25FB. We have had water leaks from the roof of the trailer. Two dealers have attempted repairs, the last the AS dealership in Seattle. The leaks have recurred with water coming along the seam in the ceiling over the kitchen, previously the leak was on the other side over the lounge. The last repair was replacement of seals around openings. Unfortunately, despite being discussed, a pressure leak test was not done as the dealership thought the seals were to blame.
The trailer is going back to Seattle dealership to try to address this. Are there any suggestion as to what else should be asked of the dealer? Is a 'pressure test" worthwhile? I am hoping to get this all addressed as a trip to the Seattle dealership with the trailer is 6 hours of driving and a $260 ferry ride (one way).
We have been quite disappointed as the amount of remedial work (replacing cabinet doors, reseating the entry door to close properly, fixing a floor flex issue) needed has been more than I would expect. Furthermore, our solar package seems to be problematic although I do not have faith in AS to address that.
Several questions for the forum -
How best to test for leaks at the dealer before we go back for the trailer?
Does the Seattle AS dealership do adequate work or should we be looking to go elsewhere?
Are there any suggestion for solar specialists in the Pacific NW closer than AM Solar?
thanks
joe
jk3805 is offline   Reply With Quote
Old 12-15-2019, 01:25 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Call Vinnie at Vinnies North Bay Airstream. He can make you whole I’m sure. Great Guy and really knows his stuff.
Old 12-15-2019, 01:53 PM   #3
2020 Classic 33
Box Elder , South Dakota
Yes to pressure test. Really the only way to find the source where penetration is occurring. Also check your Washington State lemon laws. You have some of the best protection in the country. You may be able to get reimbursement for the travel expenses.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 12-15-2019, 02:02 PM   #4
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Second above, we had a persistent leak, they have a pressure tester there. Vinnie had been fighting for a long time to get a pressure tester, after three attempts to fix our 2016 they got one, and fixed on the first attempt. The test showed them the Leak was not where they thought it was, water travels.
Matti
Mattirs is offline   Reply With Quote
Old 12-15-2019, 02:09 PM   #5
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I wish my dealer had a pressure tester; that is probably the only way to be sure, not just lucky, in finding a roof leak, especially with ducted air and that big cavity up there. Even on the sides, water can travel from the source to the observed leak.
Larry
lsbrodsky is offline   Reply With Quote
Old 12-16-2019, 10:38 AM   #6
jamieb1086's Avatar
Selbyville , Delaware
Vinnie can get it done, no question there. However your rig is under warranty. Sounds like you may have to go to Jackson Center if your warranty efforts in the Pacific northwest keep failing.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Delmarva Unit
jamieb1086 is offline   Reply With Quote
Old 12-16-2019, 10:59 AM   #7
1981 31' Excella II
New Market , Alabama
Call Jackson Center. AC gasket comes to mind on one so new. Could also be a roof sewer vent that does not have a gasket.
Perry
Old 12-16-2019, 11:55 AM   #8
Thanks for all the replies ...
New unit so will keep trying with Airstream Dealers ... we went to the Seattle dealer after a poor experience in Langley BC - we are from Vancouver island so any trip to any dealership comes with a $560 ferry ticket round trip ... this makes repeat trips less appealing
Will keep Vinnie's AS repair in mind
Hopefully third time trying to fix will be lucky
Old 12-17-2019, 02:39 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Don't forget NEVER use stabilizer jacks to level trailer. This can do a lot of damage to an AS including popping seems open causing repeated leaks, problems with door closing properly and floor flex issues.
Old 12-17-2019, 02:49 PM   #10
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Go buy two of these: https://www.homedepot.com/p/4-in-PVC...7HD4/205799563 Place them over your black and grey water vent stacks and I bet your leaks will stop.
I had leaks in my 2017's ceiling until I glued these caps over my sewer vents. On my 2018, I decided to glue these caps over my vent stacks before I had any leaks. Never had another roof leak after adding these caps over the sewer vent stacks. Here is a picture of these caps glued onto my sewer vent stacks on this thread about roof leaks: http://www.airforums.com/forums/f456...ml#post2288568
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 12-17-2019, 07:20 PM   #11
2019 28' International
Silver Springs , FL
Constant leaks.
We have a 2019 Serenity 28 ft .
After 2 trips to the factory for leaks in the rear of the unit this year we have yet another leak this time in the curved window .
We purchased the unit lightly used . The flooring is also buckled in front of the shower and the sub floor squeaks in the kitchen. It absolutely is not the cabinets as suggested. It's the subfloor squeaking on the frame .
Jackson has us scheduled for a new floor in 6 months.
Initially we purchased a new 25 foot Signature, exactly 6 months later we traded in for our current unit . We took a huge loss thinking these units work the same as with automobiles. We were given 72k back for a 5 month old 85k unit . We paid full msrp not knowing these units are negotiable. Our fault. We paid an additional 18k for our current unit .
Anyways we are at loss on how to peruse this current issue .
I do know people on the up and up watch over the forums and I believe most of the members will give us suggestions on how to proceed other than posting on the super popular Airstream Addicts Facebook page .
I absolutely love Airstream but I think this has gone too far . I've been researching Lemon Laws as well that may pertain to this unit .
Tommy Black is offline   Reply With Quote
Old 12-18-2019, 02:35 PM   #12
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi jk3805 and Tommy Black,*
We're very sorry to learn about the issues you both are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we escalate it to our Customer Service and Technical Support team.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 12-18-2019, 08:44 PM   #13
Vancouver Island , British Columbia
We from the Comox Valley too
rintintin is offline   Reply With Quote
Old 03-09-2021, 10:10 AM   #14
2015 25' Flying Cloud
Euless , TX
I have the 2015 version of this. My first question is the top fridge door. It has a design manufacture leak. The water runs off the top and gravity pulls it inside the bottom of the door. That is why there are two cut outs for it to over flow.
Much of it comes inside down at the fridge. JC caulked all the way around my fridge on the inside but, very poor design.
Please check if you have a upper fridge door if the lower fridge and floor are getting soaked.
Mine does.
Back to the roof. Mine has leaked since Jackson Center did a roof lay-over becuase of hail dimpling.
If it helps any, this is my 4th return trip in one year. They started guessing at leaks, then the pressure test w/ soap bottles on the roof and 3rd they sent it to the famous water wind tunnel at manufacturing.
My service manager was Artie and then Brad. Brad left the company last month. No replacement yet. He was the Department service manager.
VacuumKing is offline   Reply With Quote
Persistent Rear trunk water leak, Classic, Fixed?? dznf0g General Repair Forum 1 05-31-2019 10:43 PM
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 12:36 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 12:23 PM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-28-2007 12:03 AM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 06:49 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
