Old 09-08-2012, 02:58 PM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Patio light leak repaired
My patio light (2010 model AS) had condensate showing on the back side of the lens. I tried to reposition the factory gasket on a couple of occasions with no luck. Gave up and made a wider cork gasket that would not deflect from under the sealing surface of the lenses like the factroy foam gasket did.
I believe the wider gasket will work and keep the water out. You can see the cork in place under the lense here.
Hope this helps others move to a fix quicker.
ID:	167736   Click image for larger version
Alphonse is offline   Reply With Quote
Old 09-08-2012, 06:10 PM   #2
Central , Mississippi
Thats a mighty fine fix!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
HiHoAgRV is offline   Reply With Quote
Old 12-03-2012, 02:22 PM   #3
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
My factory gasket melted. To get another one, I have to buy the lens, which comes with the gasket. If I am patient, can I make one of my own?
2007 Safari FB SE LS
2008 F-250 Lariat Power Stroke Diesel Crew Cab
WBCCI 1538
To err is human. To arrrrrrr is pirate.
altamont is offline   Reply With Quote
Old 12-03-2012, 04:03 PM   #4
Alphonse's Avatar
Lower Alabama , USA
If the gasket melted, didn't the lens melt as well? I have seen many lens that have melted/deformed simply because the factory 12 volt incandescent bulb generates big amounts of heat. Btw, consider changing the bulb to a LED so it doesn't get hot.
If the lens is in good shape, yes you can make another gasket. I made the one in the photo posted above. You need a material that is quite pliable to seal this arrangement up. Cork is a pain to work with because it tends to tear and separate but I got it to work. Also be sure to make the outer diameter of the gasket to the maximum diameter of the recess where it sits in the light housing. The lens itself has a very small and ineffective sealing surface and to get it work properly you must make sure the gasket is beneath this small ridge on the lens itself. This is how these normally leak - the factory gaskets slips out from under this sealing surface and lets water in.
Old 12-04-2012, 09:27 AM   #5
altamont's Avatar
Tracy , California
The lens didn't melt. The bulb burned out and when I changed it the gasket had melted. I ordered a new LED from LED4RV which comes with a new lens, LED attached to lens and a new gasket. All for $24.95. He said it is one of their top sellers. Go figure.
WBCCI 1538
Old 12-04-2012, 10:19 AM   #6
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
This is a fine fix! I did the same to mine... Good one!
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 12-04-2012, 12:02 PM   #7
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
You can also take a small length of butyl tape and work into a snake by rolling in you hands. Place around the perimeter of the housing or on the lens. Press the lens in place and fasten. Works great, last a long time.
fltlevel510 is offline   Reply With Quote
Old 12-04-2012, 12:42 PM   #8
Alphonse's Avatar
Lower Alabama , USA
Glad you found your solution. I have a friend who also went this route and it is a good one if you don't mind LEDs with a blue tint.
Old 12-05-2012, 09:36 AM   #9
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
Blue tint LEDs...
I've found that from LED4RVs one can order either the "white" LED (which seems to have a blue tint) or the "warm" LED (which seems to have more of a yellow tint).
Decided to use the warm LEDs inside and the white ones for exterior lighting.
Either way, they sure use a helluva lot less power than the original bulbs.
Art - W0ABX
'85 Sovereign 25'er
Old 12-05-2012, 01:14 PM   #10
Alphonse's Avatar
Lower Alabama , USA
Good news, I thought the patio light only came in the bright white (blue tint).
Old 12-05-2012, 01:29 PM   #11
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Or a direct replacement LED "bulb" ...
mefly2 is offline   Reply With Quote
Old 12-05-2012, 03:02 PM   #12
Alphonse's Avatar
Lower Alabama , USA
Yeap
That's what I did
You can see it in the photos above. 300+ lumens of warm light. Warm meaning color - it doesn't get hot.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
Old 12-06-2012, 04:54 PM   #13
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
I also used the LEDS4RVs tail-light kit - much brighter and safer...
Alphonse brings up a great point - the interior LEDs don't give off heat like the originals bulbs do.
