Old 10-17-2017, 09:16 AM   #1
1995 30' Excella
Harper Woods , Michigan
no biggie, just an inexpensive & good caulk/glue syringe
Hi,
Here's an item I picked up at the Kroger supermarket. It's a turkey injector that has several features to recommend it. The barrel & plunger are made of polycarbonate, The needle & hub are standared stainless steel Luer-Lok fittings (medical style & grade). It can be fully disassembled for cleaning, including removing the luer fitting from the barrel. I would not soak in solvents, but a quick wipedown shouldn't hurt it. It might be a good idea to bore out the Luer fitting a bit. And all that for $2.50.
Bob Blarney is offline   Reply With Quote
Glue or not to glue carver 1 Floor Finishes 15 06-15-2015 06:12 AM
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
