Old 11-20-2015, 04:35 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Leaky window
I have the good fortune of having only one leak in our 66. Although it is annoying. The curved window over the kitchen sink, is the culprit. I tried ANDYR's fix using silicone and flexing it into the window to seal but it only made the leak a bit smaller.
I appreciate any ideas.
I have added sealant around the edges and under the frame from inside but the water pretty much pours onto the kitchen counter still.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-29-2015, 01:49 AM   #2
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Same problem in my front window although less so when the rock guard is closed. Also the window next to the door.
ChuckZ is offline   Reply With Quote
Old 11-30-2015, 09:25 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The fix I used was from Inland RV Andy. It was using silicone, usually a no-no for Airstreams, but it did work on the few Windows I tried it on, just not the kitchen window. Not sure why.
I am looking for an alternate plan, and asked Colin on the VAP..we will see what he says..soon.
AIR #005
retired!
Old 11-30-2015, 01:11 PM   #4
ChuckZ's Avatar
1966 26' Overlander
Thanks. On a different subject. Can you tell me how the screen door attaches to the main door so that it doesn't flop around when opening and closing the outside door? It appears that there was a snap/strap at one time but I'm not positive.
Old 12-02-2015, 03:34 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I will stop by the trailer storage spot tomorrow and check it out for you
AIR #005
retired!
Old 12-03-2015, 08:03 PM   #6
ChuckZ's Avatar
1966 26' Overlander
Thanks Alan. I appreciate it.
Old 12-04-2015, 04:30 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
went over to our Overlander today. Happy to see after a lot of rain over the past few weeks,, no leaks , no drips. Always glad to see that, plus I resealed around the vents and windows not long ago.
The screen door has what is left of this
Roller Catch
the roller without the catch. So mine flaps also when the door is open.
I remembered when looking at the door that I have forgotten to order this:
Snap Tie Back
same thing as holds the folding bathroom door to the closet.
Thanks for the poke, now I need to spend a few dollars...LOL
I went ahead and ordered both, 14 bucks well spent...
AIR #005
retired!
Old 12-22-2015, 03:24 PM   #8
ChuckZ's Avatar
1966 26' Overlander
Alan, did you install your snap tie to the screen door? If so do you by any chance have a picture of how you did it? Just wondering before I go drilling more holes in the door.
Old 12-23-2015, 09:12 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Got the snap thing a day before flying out for vacation. ..will put it on after we get back. .
Colin Hyde says the drip rail over the kitchen window will help the leak there. I have one over the front window. .it doesn't leak ....
AIR #005
retired!
Old 12-23-2015, 09:50 AM   #10
Drip caps sometimes, will work. BUT, they also tell everyone that your Airstream has had water leaks. The question then becomes "why do you want to broadcast that issue ??"
The fix is very easy. Replace the old gaskets with a updated new style gasket. When done properly, that fix corrects window leaks for at least 20 years or more. And the cost is really peanuts compared to the cost of correcting damages because of window water leaks.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-31-2015, 07:19 AM   #11
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I actually like the look of the drip caps and I have replaced the rubber in the window surround. But as always I thank you for adding to this information.
AIR #005
retired!
Old 01-30-2016, 08:28 AM   #12
1968 26' Overlander
Manheim , Pennsylvania
I too have leaks. Lots of them! The two front window are the worst and the sills fill up with water on my '68 every time it rains. A few windows were replaced by the PO with plexiglass, and of they actually don't leak! I haven't really dug into this issue yet, but I am seriously considering the drip caps. They make perfect sense! But they do take away from the smooth lines of the curved Corning Glass. Has anyone seen pictures of drip caps on a '66-'68 airstream?
SonOfAnder
'68 Overlander
https://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
Old 01-30-2016, 01:10 PM   #13
Leaky windows on a 68 are easy to fix.
Replace the gaskets, PROPERLY, with the newer style, much better sealing job, with the hollow "D" shaped gasket.
If done correctly, that will destroy the ability to leak.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-30-2016, 04:56 PM   #14
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
You know, our 67 had a bad and really pesky leak at the front window. (There are other leaks, too, but not as pesky.) I resealed that thing several times over. And resealed the window cover several times over. And nothing worked.
Until I resealed the segments on the roof above the window. Which stopped the leak in its tracks.
Lynn
ACI Big Red Number 21043
Old 01-31-2016, 04:55 PM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
good tip. I have already resealed all the seams.
AIR #005
retired!
Old 01-31-2016, 05:10 PM   #16
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Lynn , Can you elaborate on how you sealed the seams in the segment panels?
Gregsch is offline   Reply With Quote
Old 01-31-2016, 07:02 PM   #17
eubank's Avatar
Airstream - Other
1. Remove any old and loose sealant.
2. Use masking tape on either side of seam.
3. Run bead of Vulcum; smoothe into seam with finger.
4. Remove masking tape.
I've used other sealant for this, but find that Vulcum stands up longest to weathering, especially drying and cracking.
Lynn
Old 01-31-2016, 07:14 PM   #18
reinergirl's Avatar
Hollis , New Hampshire
Ditto what Lynn said, I don't have the same windows but my window leaks were all actually endcap leaks. I used foil tape to completely seal the window from the outside. When I hosed the endcap it was following the seams down and coming in at the top of the window.
reinergirl is offline   Reply With Quote
Old 02-01-2016, 07:53 AM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
to seal the seams I use an animal syringe. Large plastic, and cheap. I fill it with gutter seal and squeeze into the seams. Then clean with mineral spirits. Taping the seams with blue tape works to keep it extra neat.
AIR #005
retired!
Old 04-12-2016, 02:50 PM   #20
ChuckZ's Avatar
1966 26' Overlander
I'm in the process of beginning to remove and replace the foam seals on the Corning windows. It would appear that to remove all of the old seals and install the new ones, I will have to remove the glass to be able to get to the very top edge. Is that correct and if so how do you remove them? I can only get to a certain point and then it feels like I'm about to make a big mistake. Any thoughts?
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
Leaky Roof Window (2008 25' Safari) Mihoff Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2010 01:12 AM
Leaky window - '77 Excella nd48463 Windows & Screens 9 03-13-2009 06:02 PM
Leaky Rear Egress Window on '57 FC rookie Windows & Screens 3 04-27-2004 04:12 PM
