Old 04-12-2016, 02:58 PM   #21
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
When I owned my '66 Safari, I had two windows that leaked. I used Andy's method and the leaks stopped. Never came back in 10 years of owning the Airstream. Be sure to follow his instructions and replace the gaskets as well.
Good luck!
Steve "Centennial Man"
centennialman is online now   Reply With Quote
Old 04-12-2016, 07:39 PM   #22
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have drip caps in the garage and plan to install them on my 66. I think every Airstream trailer had drip caps except the 66 to 68 years. Drip caps help keep the "water pressure" of the hinge joints which reduces leaks. Here is a photo of a 68 Globetrotter with a drip cap over the front window. It appears to be a homemade one. I like the VTS caps better. I saw the trailer in a park.
I used the air pressure method for finding the exact point of leakage around the windows as well as other places. It is pretty effective in my view. I taped up a floor dry fan to my storage compartment and let it blow. I had to seal the fridge vent and stove vent. It was a worthwhile afternoon.
Aluminuminum has an excellent thread in the Safari section about how these Corning windows were designed and changed over the three years, with the 68s being the best. He discusses where they leak at the hinge and how to seal them. Use the search feature.
David
Name:	1505 Leak Test 2.jpg
ID:	260588   Click image for larger version
Name:	1407 68 Globetrotter Window Gutter.jpg
Old 04-13-2016, 05:21 AM   #23
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks. I have a drip rail over the front window and expect to do all the remaining ones. With a bit of extra sealant, the kitchen window now has not leaked over the past few rainy months. Makes me happy.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-13-2016, 05:53 PM   #24
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
We had a pretty bad leak over that front window, too. Resealed it. Didn't help. Removed and resealed the window cover. Didn't help.
Resealed along the curved panels along the front roof. Stopped it dead.
Remove any old, loose sealant with a sharpened popsicle stick. Start from the uppermost seam and work downwards. Tape along either side of the length of each seam. Apply Vulkem. Finger smooth. Remove tape. Repeat at next lower seam.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 04-09-2021, 07:18 PM   #25
Old Round Rock , TX
Originally Posted by Inland RV Center, In View Post
Leaky windows on a 68 are easy to fix.
Replace the gaskets, PROPERLY, with the newer style, much better sealing job, with the hollow "D" shaped gasket.
If done correctly, that will destroy the ability to leak.
Andy, where can I buy the gaskets you mentioned to replace around our windows?
Cindy Strong is offline   Reply With Quote
Old 04-10-2021, 07:23 AM   #26
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Andy passed awhile back,RIP...Inland RV is not the same.
You might try Capt.Tolley's on the narrow gap seams. Several applications may be needed, but it is quick & easy.
ID:	392854   Click image for larger version
Obrigado, hora de descansar.
Tahawus
ROBERT CROSS is online now   Reply With Quote
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
Leaky Roof Window (2008 25' Safari) Mihoff Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2010 01:12 AM
Leaky window - '77 Excella nd48463 Windows & Screens 9 03-13-2009 06:02 PM
Leaky Rear Egress Window on '57 FC rookie Windows & Screens 3 04-27-2004 04:12 PM
