Old 10-30-2016, 07:37 PM   #1
1973 31' Sovereign
Chaska , Minnesota
Leak test/Seal Cost
Howdy folks. I have a '73 AS that I've been working on for the last year. All is well...except for a leak I can't track down. If the AS is perfectly level I get water out of both the front and the back on the road side top seam. I've sealed up just about every place o can, and it still leaks!
In a heavy rain the water will come through with a consistent drop, so it definitely needs to be addressed.
Anyone out there with a rough cost of a leak test and seal job done by a AS dealer? I hesitate because of the cost, but also want this leak fixed!
Margesbarge is offline   Reply With Quote
Old 10-30-2016, 10:54 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Had a SealTech (sp?) test done at a dealer last winter. I don't have my receipt handy but I think it was 250 for the test, 250 or 300 for applying sealant.
SSquared is offline   Reply With Quote
Old 10-31-2016, 03:59 AM   #3
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 122
I had a similar issue with my 77 Sovereign. The leak was right around the area of the furnace. Sometimes it would leak profusely, other times not at all. I checked everything and everywhere... so I thought. I finally bought a small locking suction cup which I put over each and every rivet. If it locked down and held tight, the rivet was OK. If it wouldn't hold, I Captain Tolley Creeping Crack sealed it. I found one rivet that upon visual inspection looked fine, but the suction cup wouldn't hold on it. That one rivet drove me mad for too long. Problem solved. Don't expect the leak to be obvious.
You can get the suction cups on Amazon. A pair of them was only about $8. Great investment... if you have rivets... and an Airstream.
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 09-09-2017, 06:49 PM   #4
nickclifford's Avatar
1972 31' Sovereign
felton , California
pressure leak testing question
hi folks, i'm gonna bite the bullet and have a pressure test, seems like a great time saver in finding my leak. I've reached out to two airstream restorers, one can do for $350.00, the other is against pressure testing ...said that too much pressure could loosen rivets and cause more leaks.
any thoughts here ? thanks
nick
nickclifford is offline   Reply With Quote
Old 09-09-2017, 07:25 PM   #5
dznf0g's Avatar
Oswego , Illinois
Blah, blah, blah. Done with the correct pressure won't hurt ANYTHING!
-Rich-
Old 09-09-2017, 10:03 PM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
nick
Most people just use a squirrel cage fan, like an air-mover to create the "pressure". It isn't like you are using a giant compressor pump and bringing your shell up to 100psi.
If you are worried about it, just ask the tester what they use to move the air. If it is some kind of fan, then I can't imagine it doing any harm. If they have something that actually pumps, then I would be cautious.
Good luck!
Old 01-13-2018, 11:36 PM   #7
1972 31' Sovereign
felton , California
Just a quick follow up, total waste of time and money still drips and damp in the same places
Old 01-14-2018, 04:09 PM   #8
1959 22' Caravanner
Some town , Tennessee
Suction cups for dent removal tool work well for any exterior items if your doing a restoration I suggest a 50 dollar fun time grab a fog machine and fluid fill the trailer and sit back with a beer and watch for a while.
Twinkie59 is offline   Reply With Quote
Old 01-14-2018, 04:26 PM   #9
1972 31' Sovereign
felton , California
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
