Old 04-17-2025, 02:56 PM   #1
steilkurve's Avatar
2020 22' Bambi
2022 25' Globetrotter
St-Laurent , Quebec
Leak in GT 25FB kitchen
Hey all.
Was in my AS today prepping for the first outing of the season. Noticed dried water spots in the sink, counter top and microwave. Intrigued me as the AS was cleaned thoroughly when we winterized it.
Looked above and noticed a brownish residue where the two alu skins meet right above the roof lockers. Anyone had that before? My AS is stored outside and snow does collect on the roof although I remove a lot of it throughout the year. Camped a lot last Fall during heavy rains and never noticed any leak. My theories:
1) Condensation that formed after I heated the trailer a few weeks back and then of course it cooled. Was pretty cold outside. Heat rises and hit the cold snow covered roof.
2) Water pooled as snow melted and came in perhaps through the AC?
3) I replaced the skylight with a Maxim one last Fall. Caulked thoroughly and never leaked after during rain but could snow melting around it let water in from higher than the base since there was snow piled up.
Any way, I welcome your insights here.
steilkurve is offline   Reply With Quote
Old 04-17-2025, 04:18 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
steilkurve, not sure if this is applicable but I’ll share just in case.
We had water dripping from a seam in the roof skin over the toilet. It only happened after a hard, sideways rain or when I washed the trailer.
It turned out water was getting in from the tank vent; not the seal to the roof but around the gasket and the stack pipe. The 360 Siphon vent has a funnel that’s supposed to be glued into the top but during installation Airstream just drops the funnel in the vent pipe. This allows the water to get between the vent stack pipe and the seal.
I fixed it by glueing the funnel in the top part so any water is directed down the stack pipe which is in the manufacturer’s instructions. Never had a leak afterwards.
ID:	452408   Click image for larger version
ID:	452410   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 04-18-2025, 05:39 AM   #3
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Thanks Jeff. I’ve had that issue too and fixed the vent already. And it leaked in the bathroom. This seems to be a new leak. But thanks for jumping in!
Old 04-18-2025, 07:48 PM   #4
Journeyman
2016 25' International
Amherst , Massachusetts
When you replaced the very topmost cover on this toilet vent, you attached it upside down. (It's "cupped" now, but it should be the opposite, so water rolls off.). I only noticed this because I made the same mistake
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 04-19-2025, 06:53 AM   #5
jeffmc306's Avatar
McHenry , Illinois
Not following you. The cap on top?
I’m not following you on this one. The top cap came that way - I didn’t change it. In the Lippert installation instructions it shows it in this orientation.
BTW, step 2 also explains to snap the funnel into the top. Guess Airstream didn’t see that one.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 04-19-2025, 07:29 PM   #6
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Yep, Jeff is correct. The top came that way for me too on the 3 vents I replaced on 2 trailers.
25FB square kitchen sink - supplier IanPoulin Cabinets, Counter Tops & Furnishings 4 12-25-2023 12:52 PM
Another leak, bathroom 2017 25FB OSCS General Repair Forum 55 06-02-2021 05:31 AM
Must Have kitchen items for the AS Kitchen lrankine Stella's Kitchen 88 05-03-2018 01:51 PM
Run away from 'dream' 25fb w/ leak? irm Repairing/Replacing Floor &/or Frame 21 12-12-2012 10:56 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
