Old 08-11-2022, 07:17 PM   #1
1981 31' Excella II
New Market , Alabama
Latest Sealant
So what is the latest polyurethane sealant for use on the exterior. It use to be Trempro 635 but it is getting hard to find and might be discontinued.
Perry
Old 08-11-2022, 07:19 PM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Following!
Old 08-11-2022, 08:13 PM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Curious also
rugjenkins is offline   Reply With Quote
Old 08-11-2022, 09:04 PM   #4
1966 22' Safari
Fredericksburg , Texas
I’ve Used MasterSeal NP1 polyurethane caulk since we got into Airstream renovations. Used it on everything except the exterior joints where we would use Parbond. NP1 is easier to find. I’ve used it in construction since the 70s. It has worked for me.
Bubba L is offline   Reply With Quote
Old 08-11-2022, 10:13 PM   #5
2008 22' Safari
This is an easy one: https://store.airstreamlife.com/blog...icky-subject-1
Old 08-11-2022, 10:31 PM   #6
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I just hit "Vulkem 116" on the search, Amazon came up with lots. Looks like TremPro has Vulkem now.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 08-12-2022, 01:49 AM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Originally Posted by Boxite View Post
Funny - the two photos in the article show ParrBond, but it's not mentioned in the article as an option. I still use it on body seams and like the way it can be laid in a thin, narrow bead which sucks down and is hardly noticeable after it cures.
For larger areas, like over the windows and door, I used Vulkem.
On the roof around vents and such I used a self-leveling Dicor.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is online now   Reply With Quote
Old 08-12-2022, 03:49 PM   #8
1981 31' Excella II
Trempro 635 spec sheet
https://www.tremcosealants.com/files...Pro_635_DS.pdf
Vulkem 116 spec sheet
https://www.tremcosealants.com/marke...ts/vulkem-116/
116 is for porous surfaces and has some sort of solvent in it. It is slow to dry so it will pickup dirt and whatnot.
635 is faster drying and more suited to RV type applications and is solvent free.
116 might cause problems with rubber roof membranes which are no a problem on aluminum skin trailers.
There is some stuff called LEXEL that is clear and solvent based. It is real gummy but lasts a long time. LEXEL will probably disolve or swell rubber membrane roofs.
Perry
Old 08-12-2022, 05:21 PM   #9
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Good information.
10Smiles is offline   Reply With Quote
Daddy's latest project! Action Our Community 11 07-01-2005 12:06 PM
Latest Airstream Canine Diana Langley The Pet Forum 5 03-30-2004 10:09 AM
Latest Modification for Tin Hut Tin Hut Exterior Restoration Forum 10 12-30-2003 08:06 AM
latest design concepts 53flyingcloud Our Community 3 06-29-2002 10:33 AM
